sapper Options
sapper
#1 Posted : 14 December 2018 13:47:17
Have inserted batteries. Powers up OK. However, it does not move when in patrol mode, including rotation of head. Any suggestions? No troubleshooting guide available. Thanks.
#2 Posted : 14 December 2018 14:34:48
It sounds like R2 is not going through his start-up stage.
What is the spec of your batteries or can you provide a link to your battery purchase?
sapper
#3 Posted : 14 December 2018 14:50:01
Samsung 30Q button top, unprotected. Purchased from www.18650.co.uk.
#4 Posted : 14 December 2018 15:13:15
Can you confirm you have followed the troubleshooting guide here
https://forum.model-space.co.uk/...aspx?g=posts&t=30247
Have you plugged in the mains adapter into R2-D2 and plug the other end into the mains and turn it on. Leave it for a couple of seconds, then turn off and unplug both ends. (This is a protection procedure to activate the battery, and without doing this, R2-D2 won’t turn on.)
sapper
#5 Posted : 14 December 2018 16:10:03
Yes. It turns on. Get red light at front, green at rear, blue level indicator, beeps but nothing else. Press buttons, arms work, light sabre works but no patrol mode.
#6 Posted : 14 December 2018 16:17:56
In that case its possibly a wiring problem. Can you double check the wire labelling and correct placement etc
This page was generated in 0.123 seconds.
