80 Pages «<2829303132>»
#581 Posted : 14 December 2018 11:11:27
greg wrote:
what you going to do to the figures ? lol
excellent bashing
Hi Greg, thanks for looking in. As a joke, I thought I could place a German Shepherd dog wearing headphones on the Bridge and say it was a "sub-woofer"LOL
#582 Posted : 14 December 2018 11:14:50
Markwarren wrote:
Excellent work Phil, just watch out for the snakes.LOL
LOL Thank you Mark! Maybe as a laugh I could make a 1/48 scale 'snakes & ladders' board and place it in the accommodation space?LOL
#583 Posted : 21 December 2018 09:22:21
Another short update this week due to the festive period and all that entails.
On the original conning tower there are two sets of small free-flood holes on each side. Due to extensive scratch-building some of these had been filed away, so it was a case of opening these back up, albeit with a slightly different pattern as per my b/w photo.
The attached photo shows the starboard side. The three small dimples on the right hand side are the locations of the original holes and these will be filled in and sanded smooth at a later date.
#584 Posted : 21 December 2018 09:24:22
The attached photo shows the free-flood holes opened up on the port side. As with the starboard side, the holes to the left are the originals and will be filled and sanded.
#585 Posted : 21 December 2018 09:26:54
The next step was to mark out the locations for the steps that lead up each side of the conning tower. The attached photo shows the horizontal lines being drawn out using the 'pencil clamped to an engineers square' method.LOL
#586 Posted : 21 December 2018 09:30:15
All marking out finished on both sides including the vertical lines. These were drawn on after a bit of measuring to ensure the step location holes would be drilled to the correct width.
This photo shows the step location holes being drilled out with a 0.55mm diameter drill.
#587 Posted : 21 December 2018 09:31:22
All location holes drilled out on both sides. Port side shown in this photo.
#588 Posted : 21 December 2018 09:32:59
I then made up 8 steps using 0.5mm diameter brass rod. I bent them around a piece of wood which happened to be the correct width and checked them against my drilled holes for alignment.
#589 Posted : 21 December 2018 09:33:38
This photo shows the first step being test fitted using a piece of balsa as a spacer to ensure all steps protrude equidistant.
#590 Posted : 21 December 2018 09:39:47
It was at this juncture that I decided to conclude this weeks update as I still have a bit more work to get these steps fitted and modelling time will be sporadic during the next few days.
Due to the upcoming festivities my next post will be in a fortnight.
On that note I would like to wish you all a very merry Christmas and Happy New Year!BigGrin
Here's to seeing more of your model making in 2019!Cool
All the best and kind regards,
#591 Posted : 21 December 2018 12:26:20
Another great update, excellent work....Drool Drool .. Take a break and enjoy the festivities....Cool Cool
#592 Posted : 21 December 2018 13:55:59
Thank you Alan!BigGrin I hope you enjoy whatever plans you have made too!BigGrin
#593 Posted : 21 December 2018 15:50:59
Looking good Phil. This really is a mammoth project and I admire your perseverance with this lengthy build (I think I was still in short trousers when you started it!).
Keep up the good work and have a nice festive break, Merry Christmas. ThumpUp
#594 Posted : 21 December 2018 16:21:15
HahhaLOL Thank you Kev! I was still in primary school when i started it. I'm hoping by the end of 2019Blink Blink, it should be finished or just about there! Enjoy your festive break and Merry Christmas!
#595 Posted : 04 January 2019 09:25:51
This update continues with the addition of the step ladders to the sides of the conning tower.
The attached photo shows the four steps fitted to the port side.
#596 Posted : 04 January 2019 09:28:31
The attached photo shows the steps fitted to the starboard side of the conning tower with a 1.5mm square strip used as a spacer to give them equidistant depth.
#597 Posted : 04 January 2019 09:30:41
Spacer removed, steps completed.
#598 Posted : 04 January 2019 09:33:20
I then made and fitted grab-handles using the same technique and method used for the steps. The attached photo shows the port grab-handle.
#599 Posted : 04 January 2019 09:34:11
This photo shows both grab-handles fitted.
#600 Posted : 04 January 2019 09:35:10
Starboard grab-handle.
This page was generated in 0.383 seconds.
