3 Pages 123>
RSD2 failing to starting up properly Options
PeterP
#1 Posted : 12 December 2018 23:29:46
Hi I’ve been asked to start my own thread my problem is as follows :-
My R2D2 won’t start up properly on power up it jerks forward slightly, the LED on the front is RED the head doesn’t rotate, my batteries are fully charged and I have checked all the wire connections are correct way round and are in the right place and none of the pins are bent, I’ve been asked to reorder the PCB from issue 99, which I will do and get back on any progress
#2 Posted : 12 December 2018 23:36:56
Could you also post up the full spec of your batterys,this information should be available from the battery vendor.
PeterP
#3 Posted : 12 December 2018 23:39:05
My batteries are LeiFire IMR 18650 3.7V 3000mAh
the batteries are button top
as for there continuous discharge rate i can't find that out even from the vendor
but it is low but i don't know how low?
#4 Posted : 12 December 2018 23:56:23
Can you post a picture of the battery and is it protected or unprotected.
PeterP
#5 Posted : 13 December 2018 00:12:34
I assume it has protected because it has,Over charge and discharge protection
Short-circuit and over current protection
#6 Posted : 13 December 2018 00:18:28
The batterys should be the unprotected type.
PeterP
#7 Posted : 13 December 2018 00:25:00
Here a picture
PeterP attached the following image(s):
#8 Posted : 13 December 2018 00:42:06
According to the Amazon spec for your battery, it says it’s a “Protected” type battery
https://www.amazon.co.uk...lashlight/dp/B01HGBUNWK
Therefore is unsuitable to use in R2 - the magazine spec clearly states “Unprotected” type.
If this is so, you need to replace your batteries but the concerning thing is that you may have also inadvertently damaged the MCU as a result of installing Protected batteries, you’ll only discover this after you install the correct batteries and see if your R2 starts up and runs as he should or may also need to replace the MCU, might even be worthwhile doing a swop anyway.
PeterP
#9 Posted : 13 December 2018 00:47:42
Yes there are so many different type of 18650 out there
#10 Posted : 13 December 2018 10:03:25
High Peter
The batterys you will need should be unprotected and a minimum of 3 amp discharge rate or higher.
PeterP
#11 Posted : 13 December 2018 12:06:08
arpurchase wrote:
High Peter
Hi Andy
I have already ordered some unprotected button top with a 15A continuous discharge rate but 3.6v I think that should be ok? i think my previous ones where about 5A and 3.7v but protected i do hope they have not damaged the MCU? but as Tomick has suggested i have reordered issues 94 to maybe do a swop out and as you suggested I also reordered issue 99 to replace the PCB in that issue as well
stwood6
#12 Posted : 13 December 2018 15:29:22
Rank: Beginner Level 3
I know you're erroring on the side of safety, but it is really unlikely that using protected batteries would damage the MCU. The problem with the protected cells (as far as R2 is concerned) is that each individual cell has a circuit that detects high and low voltages within the cell - and will electrically disconnect the cell if it becomes over charged or over drained. Since R2 has 2 sets of 3 cells in series, if one of those cells decides it is fully charged and disconnects itself - that set will electrically drop out and the charger would continue trying to charge the remaining cells in the other set. If at least 1 cell in each set cuts off because it thinks it is fully charged - the R2 charger will now behave like there isn't a battery pack installed at all.
But if the R2 charger was built correctly, it should never apply voltage that would be high enough to damage the MCU under any circumstance (whether batteries were present or not). If anything, I could see that the charging component may be damaged if it has to deal with cells that are making their own individual decisions about when they 'participate' in the charging process.
Current Builds: R2D2, Millenium Falcon
PeterP
#13 Posted : 13 December 2018 15:38:54
But if the R2 charger was built correctly, it should never apply voltage that would be high enough to damage the MCU under any circomestance (whether batteries were present or not). If anything, I could see that the charging component may be damaged if it has to deal with cells that are making their own individual decisions about when they 'participate' in the charging process.
That thought had already cross my mind but it's better to be safe than sorry
#14 Posted : 13 December 2018 15:52:24
Unfortunately that’s not the advice given by the manufacturer, who has stated that the R2 circuitry could be damaged by the use of Protected cells.
PeterP
#15 Posted : 13 December 2018 16:56:17
After i get the new batteries i'll try R2 again if I get the same problem i'll change the MCU which I've reordered anyway and recheck all connection if i still get the same problem then i change the PCB from issue 99 which i think is a Pi microcomputer
PeterP
#16 Posted : 16 December 2018 15:33:25
Ok reassembled R2 with new batteries(Samsung 30q) fully charged, checked all wiring for correct position and orientation, pressed power button but same as before R2 jerks forward head doesn't rotate RED light on front stays on R2 makes a few beeps, BLUE legs motor lights are on, none of the back LEDS come on R2 makes a few beeps when i press the first three buttons but nothing else, i manually turn the head but i get no response, next port of call is to change MCU when it arrives if that don't do it then i change the Orange Pi microcomputer in the head......
PeterP
#17 Posted : 16 December 2018 15:47:34
The common factor in this is the MCU after checking all the wiring of course, this could be a quality control issues with the MCU, people seem to be getting the same problem weather they used protected or unprotected batteriesConfused if changing the MCU doesn't fix the problem the next thing is the Orange Pi microcomputer in the dome which is static sensitive and can be damaged easily, of course it may be worth mentioning there could be a dodgy cable and buzzing them out may reveal a bad one or more!!
semaj
#18 Posted : 16 December 2018 15:56:52
Could be worth checking the cables that link between the head boards and boards in the body. Make sure they are properly connected. I saw a video on youtube where 1 chap was having all manner of trouble. Turned out to simply be one of them cavlea wasn't properly plugged in.
Building:
Complete:
PeterP
#19 Posted : 16 December 2018 16:00:04
Yes i did check to make sure they are right way round and properly seated
#20 Posted : 16 December 2018 16:06:51
Indeed your problem may well be the MCU as a result of installing “Protected” batteries to start with., So it seems the only way forward is to replace the MCU and go from there.
In actual fact, the biggest factor so far with most problems reported, is incorrect batteries, incorrectly labelled wires, incorrectly plugged wires and plugs not properly fitted.
3 Pages 123>
This page was generated in 0.412 seconds.
