There really is some fine detail going into this build. It's a pleasure to watch Regards Gray
pemberg wrote:Nice work with the handrails and brackets - looks very effective.
Graeme Thank you Graeme.  Fiddly work but I think it carries the look well. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
CaptnBirdseye wrote:There really is some fine detail going into this build. It's a pleasure to watch Regards Gray Thank you very much Gray!  I'm glad you're enjoying the process! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Another complex step done beautifully, looks superb.... Regards Alan
Gandale wrote:Another complex step done beautifully, looks superb.... Regards Alan Thank you very much Alan. Your comments are always appreciated!  Next up will be grab handles, guard rails, steps and ladders. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Great work and stunning attention to detail as always!Greetings, Walter
DaDokta wrote:Great work and stunning attention to detail as always! Thank you Walter!  Fiddly work but it's starting to take shape. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Good morning from 'The Dockyard'. Just a short update this week which sees the addition of two step ladders to the rear of the lower deck of my 1/48 scale modified conning tower. I initially thought making these would be a '5 min job'  , but due to the fact that they were small and fiddly, i ended up restarting after the first attempt. While building the Mk2 version I had to remedy the odd breakage or two during construction, meaning that these step ladders actually took me three evenings to get right. I used 1.0mm square plastic strip for the uprights and 1.0mm diameter round rod for the rungs. As I wanted them to sit vertically, I had to spend a bit of time filing and trimming the bottom supports of the step ladders to accommodate the tapered profile of the lower deck sides. The step ladders are 20mm long and 6mm wide. The attached photo shows both ladders prior to fitting. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
You can just make out in the attached photo the difference in length between the longer supports of both step ladders which fit against the tapered lower deck. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Both ladders turned around to show the other side. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The first step ladder fitted to the starboard side of the conning tower lower deck. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The second step ladder fitted to the port side of the conning tower lower deck. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
A view from above showing both ladders attached. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Well that concludes this weeks very short update, so i'd better crack on with the Christmas shopping!  Thanks for looking in and your comments, have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looking good as always Phil, nice work
pemberg wrote:Looking good as always Phil, nice work
Graeme Thank you very much Graeme! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
More great progress Phil... onwards and upwards..... Regards Alan
Gandale wrote:More great progress Phil... onwards and upwards..... Regards Alan Thank you very much Alan!  It's slowly starting to take shape. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
 Rank: Amateur Level 1  Groups: Registered
Joined: 30/09/2018 Posts: 36 Points: 98 Location: California
what you going to do to the figures ? lol excellent bashing NOW - Building SWIFT 1805
long term goal "USS Constitution" completed "Fair a Frame" by Model Shipways
Excellent work Phil, just watch out for the snakes. Mark Regards Markwarren (Mark) Admin
