mistake on part 3 of download instructions or pack 3 of magizine instructions Options
ronald305
#1 Posted : 12 December 2018 20:28:40
Hello there
has anyone notice the mistake on either the downloaded instructions of part 3 page 114 or the magazine instructions pack 3 page 158 both are part # 5 when calling to do the next plank # 14 it says to lay the plank between 16 and 25
the question is since I can not do 16 to 25 do I go forward one rib like 16 to 23 or back a rib like 18 to 25 what do I do here any suggestion would be fine, PS - no need for a photo here
Ronald
#2 Posted : 12 December 2018 21:46:29
Hi Ronald,
Frames 16 to 25 is wrong and was corrected on the Official Build for Stage 28 as can be seen here
https://forum.model-spac...aspx?g=posts&t=1359
The first plank in this step should be laid between frames 16 and 23.
If you think you see any errors then refer to the Official Build for that stage to see if any changes were made.
Hope this helps..
ronald305
#3 Posted : 12 December 2018 22:09:21
that's what I thought thanks Alan
Ronald
