ModelSpace
Period Ships
HMS Victory
HMS Victory - Model Build Discussion
mistake on part 3 of download instructions or pack 3 of magizine instructions
 Rank: Pro Groups: Registered
Joined: 08/02/2015 Posts: 426 Points: 1,259 Location: Louisiana
Hello there has anyone notice the mistake on either the downloaded instructions of part 3 page 114 or the magazine instructions pack 3 page 158 both are part # 5 when calling to do the next plank # 14 it says to lay the plank between 16 and 25 the question is since I can not do 16 to 25 do I go forward one rib like 16 to 23 or back a rib like 18 to 25 what do I do here any suggestion would be fine, PS - no need for a photo here Ronald
Hi Ronald, Frames 16 to 25 is wrong and was corrected on the Official Build for Stage 28 as can be seen here https://forum.model-spac...aspx?g=posts&t=1359
The first plank in this step should be laid between frames 16 and 23. If you think you see any errors then refer to the Official Build for that stage to see if any changes were made. Hope this helps.. Regards Alan
that's what I thought thanks Alan Ronald
ModelSpace
Period Ships
HMS Victory
