3 Pages 123>
R2D2 not completing start up. Options
StevePB
#1 Posted : 12 December 2018 08:32:30
Hi guys - I've got a problem with my R2D2. It wont start up Crying . On power up it moves forward slightly but that's it. LED on front is RED and head does not move. Batteries are fully charged, in the correct way and after initialisation there is 12.5V on the main output, before initialisation 0V (black plug). Possibly related it does not sense that it is being charged, charger does charge the batteries but the indicator LED just stays red. I've checked all the wiring and cant see any missing, in the wrong ports or inserted incorrectly.
Help!!
#2 Posted : 12 December 2018 08:54:08
Checkout the R2 troubleshooting guide, the link is below.
https://forum.model-space.co.uk/...aspx?g=posts&t=30247
#3 Posted : 12 December 2018 09:02:47
Hi steve
Can you check your battery's are making full contact at both ends in the battery box.
Thanks
#4 Posted : 12 December 2018 11:42:55
Also, are your batteries proper 'button top', can you post a photo of the button top end?
figuerres
#5 Posted : 12 December 2018 14:41:26
forum admins: i posted a thread asking if the guide can get a list of the r2 init steps to help us work out what issues we have.
but so far no reply on that.
the trouble shooting post is where it goes but i was not able to post on that topic i guess it's locked.
if we know the order and we see some things happen and then it stops then we can compare that to the list and narrow down what the fault might be.
for example left leg then right leg or right leg then left leg ??
#6 Posted : 12 December 2018 14:51:36
No response to it because at the moment we are concentrating on resolving individual problems as being the priority to resolve. That’s not to say it won’t be done, just that there are other priorities right now.
figuerres
#7 Posted : 12 December 2018 16:59:55
i understand that, just that my post had no reply at all so i did not know if it had even been read by any of the admins.
a simple "Got it" would have let me know.
PeterP
#8 Posted : 12 December 2018 17:28:59
Help!!
I have exactly the same problem!!!!!!!!!!!!
and i have checked everything, of course the next question is what is your batteries continuous discharge rate?
#9 Posted : 12 December 2018 18:18:58
Hi Peter can you check with a test meter [if you have one]if you are getting power from the battery box by testing the power lead from the battery box.
StevePB
#10 Posted : 12 December 2018 18:41:17
arpurchase wrote:
Hi steve
Thanks
They are, voltages all check out also.
PeterP
#11 Posted : 12 December 2018 18:41:42
Is that with the battery box connected or not?
PeterP
#12 Posted : 12 December 2018 18:43:37
I'm suspecting my batteries as they have a low continuous discharge rate if not them then it's the MCU!!!!!!!!!!!!!
StevePB
#13 Posted : 12 December 2018 18:54:16
Yes they are - image attached of batteries from seller and installed correctly in battery box.
StevePB attached the following image(s):
StevePB
#14 Posted : 12 December 2018 18:59:22
PeterP wrote:
Help!!
High discharge type for me 30A !! - As for problem it not sensing charging points to either battery box itself or MCU :(
PeterP
#15 Posted : 12 December 2018 19:04:56
StevePB wrote:
PeterP wrote:
Help!!
Well your batteries look good ThumpUp it's hard to think of what else it could be other that the MCU Confused
#16 Posted : 12 December 2018 19:32:52
Do the test with the batterys in the battery box but taken out of R2 so your testing the contacts that go into R2'S black box.
#17 Posted : 12 December 2018 19:35:53
StevePB wrote:
PeterP wrote:
Help!!
Can you also double check all your leads are labeled and places correctly as per the instructions and that all pins are straight where the conectors go in.
PeterP
#18 Posted : 12 December 2018 19:39:48
12.29v on the black plug
#19 Posted : 12 December 2018 19:45:39
The battery box looks ok.
PeterP
#20 Posted : 12 December 2018 19:50:45
What i'm not sure of is when I check the batteries individually they are all about 4.11v each which means there is about 24v going into the battery box but only 12.29v coming out?
3 Pages 123>
