Help!!!!!! Options
sirbawbag
#1 Posted : 10 December 2018 20:44:39
hi all, after completing my build and going through the start up process when i turn R2 on all i'm getting is the coloured lights in the rectangle on the dome and blue lights at the bottom of the legs, please help!!!!
#2 Posted : 10 December 2018 21:03:59
You need to double check all your wires are labeled in the correct manner and then make sure there inserted into there correct sockets. Some assemblers have managed to reverse the head limit switch cables.
sirbawbag
#3 Posted : 10 December 2018 21:26:11
All connections checked and double checked? could it be the batteries? They said they had no protection, how can I tell?
sirbawbag
#4 Posted : 10 December 2018 21:35:22
sirbawbag attached the following image(s):
#5 Posted : 10 December 2018 21:57:00
Can you confirm the amperage output of the above batterys.
sirbawbag
#6 Posted : 10 December 2018 22:16:39
Not very good at this, how do I do that?
#7 Posted : 10 December 2018 22:35:17
Ask the shop you bought them from they should know the continuous discharge capacity of your batterys.
Some one posted a link to some Samsung 30Q batterys earlyer if you look at the battery spec on the 7th line down it says-
Discharge: 15A Max Continuous.
The above is what you need to find out.
Link here-
https://18650.uk/product/samsung-30q-button-top/
sirbawbag
#8 Posted : 10 December 2018 22:49:19
Not sure about the batteries I bought, but I’ve ordered different ones , they have a maximum continuous discharge of 20A is that ok?
#9 Posted : 10 December 2018 22:57:08
They sound good
sirbawbag
#10 Posted : 10 December 2018 23:02:45
Thanks for your help I will let u know how I get on when the new ones arrive
This page was generated in 0.106 seconds.
