2 Pages <12
HELP!! My R2 Does not work Options
Spudtrooper37
#21 Posted : 09 December 2018 19:26:21
I have now come to the conclusion that the test board from issue 52 is broken.
I guess all the plugging and unplugging of the cables has not done it much good.
I have ordered issue 52, finger's crossed when it arrives that will sort it.
Darren
PeterP
#22 Posted : 10 December 2018 20:23:52
I've completed my R2 but it not work properlyConfused , when i press the power button it jerks forward but the head doesn't rotate or move at all, the front red light stay on i have full charged the batteries R2 makes a few beeps, I've rechecked all the connections and there correct is there any way of checking the head motor is functional? or could there possible be a problem with the MCU? I'm stumped!! any ideas?
figuerres
#23 Posted : 10 December 2018 20:31:14
from what i have read the head motor is really the same as the foot motor so using the foot motor test should also be usable for the head.
also the head should power on during init, we just need to know more about the order in which the systems are checked on power up ....
#24 Posted : 10 December 2018 20:39:49
You need to double check all your wires are labeled in the correct manner and then make sure there inserted into there correct sockets. Some assemblers have managed to reverse the head limit switch cables.
PeterP
#25 Posted : 10 December 2018 20:48:47
Ok I've gone back to issue 34 and done the check and it seems to work does that mean the MCU not working properly
PeterP
#26 Posted : 10 December 2018 20:53:38
Yes I have check all the wires and they are labelled correctly i was meticulous about that, and in the correct sockets
#27 Posted : 10 December 2018 21:07:20
Please could you recheck them to be sure.
PeterP
#28 Posted : 10 December 2018 21:36:01
Yes rechecked again looks like the little guy is dead in the waterCrying
#29 Posted : 10 December 2018 22:06:55
Can you confirm the amperage output of the above batterys.
PeterP
#30 Posted : 10 December 2018 22:18:52
3000 mAh
#31 Posted : 10 December 2018 22:37:55
PeterP wrote:
3000 mAh
That is the milliamps of the battery not the discharge amps which is the figure you need. Ask the shop you bought them from they should know the continuous discharge capacity of your batterys.
Some one posted a link to some Samsung 30Q batterys earlyer if you look at the battery spec on the 7th line down it says-
Discharge: 15A Max Continuous.
The above is what you need to find out.
Link here-
https://18650.uk/product/samsung-30q-button-top/
PeterP
#32 Posted : 10 December 2018 23:01:24
Unknown, they have a low discharge rate
#33 Posted : 11 December 2018 07:07:33
Your battery supplier should be able to provide you with the Amperage output information(Amps).
PeterP
#34 Posted : 11 December 2018 15:48:46
Unfortunately they are just a general supplier off the internet and don't have that information, but I've now gone to 18650uk and bought Samsung 30Q Button Top which is 15A Max Continuous Discharge
Spudtrooper37
#35 Posted : 07 January 2019 02:01:15
Hi all, a bit of an update on my R2, Issue 52 arrived so I could change the circuit board, got it fitted today and he now works 😁 not fully but about 95% (voice control and projector not working)
In antomonous mode and patrol mode he did not like the tiled floor or tables (see video)
He works fine now, avoids tables and happy on the tiled floor.
I am happy now, had fun with him today (wife said he is noisey on the floor)
which he is, only wish deagostini had made his wheels out of rubber
Will address the other issues at a later date.
Thanks for the help everyone.
Darren
#36 Posted : 07 January 2019 08:50:27
BigGrin Thanks for the update Darren and have fun with himCool
Highwayman
#37 Posted : 07 January 2019 20:22:29
you seem to have the same problem as I have with mine - in autonomous mode, none of the front sensors in the body ad shoulders do anything. I was told to call CS for a replacement MCU
Spudtrooper37
#38 Posted : 10 January 2019 20:54:54
It is a weird one 🤔
Is yours fully working on the app?
I'm just happy he is working with the app,
I just need to get a new projector at some point once they become available 🙄
Darren
2 Pages <12
This page was generated in 0.155 seconds.
