Head mount - check for rocks in the shaft Options
figuerres
#1 Posted : 07 December 2018 14:44:02
last night i got month 24, that has the parts for the head motor and shaft.
in my package the mounting shaft had a bit of some rock like stuff stuck inside.
if you do not see it and try to assemble then it will not fit right.
so check the part.
i have two photos to show the part and where the rock was.
#2 Posted : 08 December 2018 00:47:20
I would order a replacement from C/S
figuerres
#3 Posted : 08 December 2018 17:19:52
no need to do that in my case.
i got the rock out of the shaft and the center axle rod fits in the way it should.
if i had not been able to remove it then i would need a replacement.
by the way it was a chunk of "polishing stone" used to finish a part.
generally not going to get one stuck inside like that but i can happen.
