80 Pages «<2627282930>»
#541 Posted : 07 December 2018 09:30:58
Starting at the rear of the conning tower and using my prototype based method, i proceeded to 'thread' brackets along a pre-cut length of the brass rod / handrail and inserted each bracket into it's allocated hole.
#542 Posted : 07 December 2018 09:32:56
This photo shows a piece of 0.5mm thick plastic sheet being inserted behind the handrail to act as a spacer to keep it at a uniform distance around the curved profile of the lower deck.
#543 Posted : 07 December 2018 09:33:44
As before, a similar type of spacer being used to ensure the handrail is at a uniform distance all the way around.
#544 Posted : 07 December 2018 09:34:42
Handrail completed on the lower deck.
#545 Posted : 07 December 2018 09:35:46
Looking at the same handrail from the rear.
#546 Posted : 07 December 2018 09:36:16
From another angle.
#547 Posted : 07 December 2018 09:37:47
This photo shows the full profile of the lower deck handrail from the port side.
#548 Posted : 07 December 2018 09:38:47
A full length photo of the same handrail on the starboard side.
#549 Posted : 07 December 2018 09:39:59
The second section of handrail fitted to the main conning tower body.
#550 Posted : 07 December 2018 09:41:58
Looking from another angle.
#551 Posted : 07 December 2018 09:42:36
Looking from the front.
#552 Posted : 07 December 2018 09:43:23
Starboard side view showing the handrails in place.
#553 Posted : 07 December 2018 09:44:25
The attached photo shows the third section of handrail fitted.
#554 Posted : 07 December 2018 09:45:02
The fourth and final section of handrail fitted.
#555 Posted : 07 December 2018 09:47:49
That concludes this weeks update.
Thanks for looking in and your comments. Have a great weekend and happy modelling!BigGrin
#556 Posted : 07 December 2018 11:14:49
Nice work, it looks like it's getting a fine tune. Love
#557 Posted : 07 December 2018 12:17:48
Great work Sticky,very well done.
Trev.
#558 Posted : 07 December 2018 12:34:01
Thank you Mark!Cool Bit fiddly and yes, fine tuning all the way now. Cool
#559 Posted : 07 December 2018 12:35:02
Trev.
Thank you very much Trev!BigGrin Cool
#560 Posted : 07 December 2018 12:50:32
Nice work with the handrails and brackets - looks very effective.
Guest (5)
This page was generated in 0.376 seconds.
