R2-d2 not coming on line properly Options
Steven123
#1 Posted : 06 December 2018 22:45:39
Hi all, after finishing the build and following the start up procedures , the R2d2 switch’s on rocks forward turns dome clock wise, but keeps turning clock wise after it hits the stop and won’t turn back, have checked all connections and are all connected correctly, can anyone help cheers
skittles
#2 Posted : 06 December 2018 23:03:09
Sounds like the end stop sensor isn't working or wired up wrong way round. The easiest way to check is to unplug the head wires and completely remove the head. It's ok to switch on with the head disconnected. Power up and you'll see the head motor turning. Gently place a piece of card in the right sensor. The head motor should stop. If not try the left sensor. If it suddenly turns the other way then it's the sensor wires crossed.
semaj
#3 Posted : 06 December 2018 23:19:26
another possibility is that you fitted the Y shaped assembly on the base of the dome in the wrong orientation. one of the arms has a piece sticking down off it that has to contact the sensor to stop the rotation. ensure you have correctly fitted that part
Building:
Complete:
Steven123
#4 Posted : 06 December 2018 23:22:22
Hi thanks for the fast reply will let you no how I get on cheers
Steven123
#5 Posted : 06 December 2018 23:23:14
Hi while your on what app is it that you get? Cheers
#6 Posted : 06 December 2018 23:23:45
Double check the sensor conections are assembled corectly and retry the start up.
Steven123
#7 Posted : 07 December 2018 20:17:46
Hi all , have taken head off and started R2d2 up the head just turned clock wise and doesn’t stop when you put a card or ruler in eather stop sensors! Could it be the sensors? Any advice would be much appreciated .
Steven123
#8 Posted : 07 December 2018 20:30:49
I have retested the sensor stops and they are working?
Steven123
#9 Posted : 07 December 2018 21:56:11
So would it be the control module?
#10 Posted : 07 December 2018 22:53:43
Call C/S for a replacement Issue 94.
Steven123
#11 Posted : 08 December 2018 08:10:20
Hi there where would I find there number? Cheers
#12 Posted : 08 December 2018 08:15:46
On the inside front cover of the magazine 0333 300 1049 Mon-Fri 9-5
Steven123
#13 Posted : 08 December 2018 08:41:35
Cheers
SamuelG
#14 Posted : 08 December 2018 11:20:15
Rank: Newbie
Hi there I had the same problem and I found the fix. 1st on mine on the MCU board at the left head sensor LH-IR there was a pin missing, it came like tht (see image attached). I solder another pin there and tested again. Now the problem with mine was that the head movement was to aggressive both towards the roght and than left. Lucky for me when I purchesed the leg mottor few months back the newsagent had a duplicate and i both them both. This morning frustrated I said let me test that motor and see how that one behaves and guess what that one works as it should. The only thing that I have to do now is to swith the mettal head of the motor as the leg motor head is bit different than the one for the head. If you are part of the Facebook group Build your own R2-D2 you ll see there more videos
Steven123
#15 Posted : 10 December 2018 09:44:28
Thanks for that
This page was generated in 0.240 seconds.
