arpurchase wrote:Its a location line for the in flight refueling arm assembly to fit, once in place the line is not noticable.
Oh ok, that makes sense now. Thanks for the insight Andy.
Kev  Per Ardua Ad Astra
So on the above note I took the time to look through the destructions to see how the refueling arm fits. I looked for the holes I needed to drill out and they are, how shall we say, a bit hit and miss! So I cut the pins off the arm mount and did it my way. The arm mount is a lousy fit so I glued it in sections, flowing ultra thin glue down the seam. Luckily there is an outline of where it fits so I had something to go by. Nemesis attached the following image(s):
That's a big model, should look impressive
Great kit, wow that’s big. I hope you’ve got enough room for a hanger in you garden for that. Great start, will be watching with interest. Mark Regards Markwarren (Mark) Admin
Making great progress Nem, certainly going to be a beast of model to display.. Regards Alan
Nice work Nem, Looking good. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Good luck with your build Nem. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Nice work as always Daran, looking good and certainly forging ahead with your build. Well done.
It's certainly large, great job so far, looking good.
Certainly is a whopper Daran. Think you'll need to build a hangar in the garden for it mate, can't see your lovely lady allowing that to stay indoors.
Nice update Nem. Cockpit looks great.  Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Lovely work, looking excellent. Mark Regards Markwarren (Mark) Admin
Nice detailing in the cockpit Nem. Coming along a treat. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
