13 Pages «<10111213>
Anakin Skywalker's Podracer Diorama Options
#221 Posted : 26 November 2018 23:10:48
Many thanks for the kind comments.
I have now finished the electronics to run this diorama with spinning turbines, jet engine flames and lit up cockpit as well as sound effects. This was one task I was not looking forward to.Crying I decided to get this part of the build done before finishing the remaining diorama, and I’m glad I have. Now I can concentrate on the rest of the build without fretting about how I was going to make it all work.
In these pictures you can see I have adopted larger speakers. These give a much better sound with good base and clarity.
I have also finished programming the main sound board and it’s now all wired with small connectors making it easy to attach the top half to the base part. I still have the cable to do in the underside of the case where the cables from the podracer run through the tubes in the rock. But the hard part is now done, and everything works just fine. Yehhhhhh
Now back to modelling.
Cool ThumpUp
#222 Posted : 26 November 2018 23:48:18
Look well complicated Mark, pleased it all worked out for you in the end....Cool Cool ...Looks great
#223 Posted : 27 November 2018 04:40:03
Great job MarkBigGrin look forward to seeing it all in action once the build is complete.
#224 Posted : 27 November 2018 07:44:19
BigGrin All looking good and nicely doneCool
#225 Posted : 27 November 2018 08:19:08
Thank you for your comments, hopefully have it all up and running very soon.
#226 Posted : 03 December 2018 08:36:22
I have now painted the whole rock formation with burnt umber paint. I then added modelling sand, different grades and a few more small rocks. These were all glued in place and allowed to dry overnight before painting it all again with burnt umber. Once it was dry, I then used a combination of different coloured pigments and mixed them to a colour I was satisfied with. This was carefully brushed over the rocks before using lighter pigments to give the rocks a more realistic look. I have also used some scenic foliage in places to break things up a little.
The next step is to matt varnish the whole thing, starting with a very light dusting, so not to lose the sandy powdery look and seal in all the pigments and paint.
Then it will be to paint some lighter shades through the rock and sand areas to create light and shadow effect.
I know when I started this project I said there would be an Easter egg to find, well it is now in place. But…. Don’t try to find it as I have purposely hidden it from camera view and all will be revealed when complete.
More soon…..
#227 Posted : 03 December 2018 09:37:50
Stunning work Mark, looks amazing.....Love Love
#228 Posted : 03 December 2018 10:24:36
Fantastic work Mark!Love
#229 Posted : 03 December 2018 15:06:40
Very impressive ground work Mark, looks so realistic.
#230 Posted : 03 December 2018 16:41:59
Looks amazing
#231 Posted : 03 December 2018 18:15:32
FantasticDrool Drool regards PhilCool
#232 Posted : 03 December 2018 19:25:09
Many thanks for the kind comments guys, very much appreciated. Cool
#233 Posted : 03 December 2018 20:35:37
Just had a catch up, absolutely stunning!Drool Love Cool
#234 Posted : 03 December 2018 21:31:42
Thanks Nem for your support.
#235 Posted : 04 December 2018 00:31:43
Superbly done MarkCool really impressive work.
Andreas
#236 Posted : 04 December 2018 09:04:08
Groups: registriert
Hi Mark
Excellent work!, absolutely real!, just great!!BigGrin
Andreas
Forum Support Team
#237 Posted : 08 December 2018 15:56:44
Back ground looks fantastic Mark, very well done. look forward to seeing it all put together. BigGrin Drool
#238 Posted : 08 December 2018 19:47:06
Many thanks for the kind words.BigGrin
Getting closer to the finishing line. I have matt varnished the diorama rock and applied some lighter sand colours to add shadow. I was very pleased with the result as I have retained the powdery sand feel. I have also removed all the masking tape and then sprayed a light coat of black paint around the edge to blend in with the base.
I have also finished the pod and engines and they are now ready to attach to the diorama. The only outstanding part left is to paint Anakin himself. I have also added some lighting to the front of the base where the brushed steel name plate will be backed with luminous Perspex to have a blue hue around the plate to match the blue lit switches.
I have also nearly completed the electronics as shown.
More very soon…
#239 Posted : 08 December 2018 21:03:25
All looking very impressive Mark, top notch work....Drool Drool
#240 Posted : 08 December 2018 21:40:11
Superb work, looking very impressive
