 Rank: Amateur Level 1  Groups: Registered
Joined: 04/09/2010 Posts: 38 Points: 94 Location: cape town, south africa
My wheel...is it correct or incorrect? Comments appreciated. [O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][/6_IMG_20180801_132247s3.jpg] Built: HMS Victory
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,192 Points: 15,725 Location: ipswich
I'm afraid it looks wrong.
The uppermost two layers of spokes in your picture should cross over each other. Have a close-up look at the other wheel pics posted. You can see the cross-over quite clearly, very near the central hub.
I can appreciate taking it apart again now might be a bit of a headache so if that's your first wheel, maybe leave it alone and use it as the spare in the boot. Watch out more closely when you build the remaining 4 wheels...
Roy.
I can't see my wheel on my post???? But if you can I will look it along with the others in Photoshop and try see the differences. Thanks. Built: HMS Victory
roymattblack wrote:I'm afraid it looks wrong.
Roy. I'm afraid I can't find the post which shows the correct spoking. Could you reply with a pic so that I can compare, otherwise I'll dig the issue out again. Thanks for your patience with a newbie. Built: HMS Victory
here is a photo roy put up for you, he has circled the area yellow, take a look compared to yours, hope this helps. Steve1701 attached the following image(s):
I've attached a couple of very simplistic drawings of a pair of upper spokes. One shows how they should be fitted, the other shows your arrangement. Hope it helps. Roy. roymattblack attached the following image(s):
Thanks a Gazillion... at last I've got it! Built: HMS Victory
