benni Options
benni
#1 Posted : 01 December 2018 11:36:37
Rank: Amateur Level 1
My wheel...is it correct or incorrect? Comments appreciated.Blushing
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][/6_IMG_20180801_132247s3.jpg]
Built: HMS Victory
#2 Posted : 01 December 2018 11:45:56
I'm afraid it looks wrong.
The uppermost two layers of spokes in your picture should cross over each other.
Have a close-up look at the other wheel pics posted. You can see the cross-over quite clearly, very near the central hub.
I can appreciate taking it apart again now might be a bit of a headache so if that's your first wheel, maybe leave it alone and use it as the spare in the boot.
Watch out more closely when you build the remaining 4 wheels...
Roy.
benni
#3 Posted : 01 December 2018 11:56:23
I can't see my wheel on my post???? But if you can I will look it along with the others in Photoshop and try see the differences. Thanks.
Built: HMS Victory
benni
#4 Posted : 01 December 2018 12:02:33
Roy.
I'm afraid I can't find the post which shows the correct spoking. Could you reply with a pic so that I can compare, otherwise I'll dig the issue out again. Thanks for your patience with a newbie.
Built: HMS Victory
Steve1701
#5 Posted : 01 December 2018 12:10:24
here is a photo roy put up for you, he has circled the area yellow, take a look compared to yours, hope this helps.
Steve1701 attached the following image(s):
#6 Posted : 01 December 2018 12:40:34
I've attached a couple of very simplistic drawings of a pair of upper spokes.
One shows how they should be fitted, the other shows your arrangement.
Hope it helps. Roy.
benni
#7 Posted : 01 December 2018 17:10:46
Thanks a Gazillion... at last I've got it!Blushing
Built: HMS Victory
This page was generated in 0.192 seconds.
