80 Pages «<2526272829>»
#521 Posted : 30 November 2018 10:26:26
Markwarren wrote:
Looking excellent Phil.Cool
Thank you very much Mark!Cool BigGrin
#522 Posted : 30 November 2018 10:27:46
Looking fab, great example of some scratch building.....Drool Drool .. Very well done...
Thank you Alan!Cool Much appreciated!BigGrin
#523 Posted : 30 November 2018 10:28:39
Garth wrote:
Hi Phil,
Lovely update as always.
Thank you for looking in Garth! Much appreciated!BigGrin Cool
#524 Posted : 30 November 2018 10:29:11
arpurchase wrote:
Thank you very much Andy!BigGrin Cool
#525 Posted : 30 November 2018 11:14:45
Another great update, this is going to look fantastic when finished.
#526 Posted : 30 November 2018 16:13:27
Thank you very much Graeme!BigGrin Cool Much appreciated, but a long way to go yet!LOL
#527 Posted : 30 November 2018 18:02:52
Great attention to detail on this build Cool very well done.
#528 Posted : 30 November 2018 19:51:39
Some more fab scratch-building from you Phil and another nice update.
It's very interesting watching this build develop. ThumpUp
#529 Posted : 03 December 2018 10:20:31
Thank you very much Al!BigGrin
#530 Posted : 03 December 2018 10:21:32
Thank you Kev!Cool Nice to see you back.
#531 Posted : 03 December 2018 18:17:18
Great as always Phil Drool regards PhilCool
#532 Posted : 03 December 2018 23:08:11
looking stunning PhillCool BigGrin
#533 Posted : 04 December 2018 10:43:40
Thank you very much Ian!Cool BigGrin
#534 Posted : 04 December 2018 10:44:43
Thank you very much Phil. Your comments are much appreciated!Cool BigGrin
#535 Posted : 07 December 2018 09:20:53
In this weeks update I fitted handrails to the conning tower.
The handrails are made of 0.5mm diameter brass rod. Very thin, easily bent when you don't want it to and very fiddly.Blushing
I spent a bit of time trying to figure out how I would fix the handrails as I didn't want the brackets to look out of place scale wise and not appear 'to chunky'.
I decided to make the brackets using the same 0.5mm brass rod. I started by clamping a small length of the brass rod in a vice to act as a guide then took a similar length which would form the bracket and proceeded to bend it around the clamped piece. I then carefully crimped the neck of the bracket to bring it in tight around the clamped rod.
See attached photo of the first prototype bracket.
#536 Posted : 07 December 2018 09:22:21
The attached photo shows the prototype with a sample length of handrail inserted so I could check that all looked good.
#537 Posted : 07 December 2018 09:24:04
The prototype sample from another angle. I then had to make 18 of these brackets, which actually turned out to be about 24 in the end as 6 snapped as I crimped the ends!Blushing
#538 Posted : 07 December 2018 09:25:56
The next step was to draw a guideline around the perimeter of the conning tower using a pencil clamped to an engineers square so that I could drill out the locating holes for the brackets.
#539 Posted : 07 December 2018 09:26:29
Guideline marked out and bracket locating holes drilled.
#540 Posted : 07 December 2018 09:27:40
The attached photo shows the continuation of marking out and drilling the bracket locating holes.
This page was generated in 0.323 seconds.
