benni's E-type Options
benni
#1 Posted : 30 November 2018 10:06:29
Rank: Amateur Level 1
The next few steps. No problem with the wheel...I was expecting the worst from reading all the posts, but if you just follow the instructions it was pretty simple.BigGrin
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][3_IMG_20180731_182102s.jpg]
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][4_IMG_20180731_183202s.jpg]
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][5_IMG_20180731_184303s.jpg]
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][6_IMG_20180801_132247s2.jpg]
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][7_IMG_20181124_095343s.jpg]
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][8_IMG_20180905_141337s.jpg]
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][9_IMG_20180905_141625s.jpg]
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][12_IMG_20180917_132411s.jpg]
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][16_IMG_20181119_131140s.jpg]
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][17a1_IMG_20181127_121204s.jpg]
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\My build diary\small jpgs][17a2_IMG_20181128_083852s2.jpg]Blushing
benni attached the following image(s):
Built: HMS Victory
Steve1701
#2 Posted : 30 November 2018 10:10:27
noticed you have not crossed the spokes on the second set. was this intentional.
Steve1701 attached the following image(s):
benni
#3 Posted : 30 November 2018 11:39:23
That pic was from an early stage before I added the third set. The completed wheel pic doesn't want to upload??
Built: HMS Victory
#4 Posted : 30 November 2018 12:15:21
The pic does look as if all the spokes are fitted.
The upper two rows should cross over each other very close to the central hub.
If you look at my pic hopefully you can see what I mean...
This page was generated in 0.128 seconds.
