80 Pages «<2425262728>»
#501 Posted : 29 November 2018 22:48:20
From above.
#502 Posted : 29 November 2018 22:49:41
This photo shows the slits opened up slightly with sandpaper, so that they could except the 0.5mm thick supports.
#503 Posted : 29 November 2018 22:50:46
This photo shows the supports that will fit into the slits.
#504 Posted : 29 November 2018 22:53:30
Supports glued in place.
#505 Posted : 29 November 2018 22:54:00
From another angle.
#506 Posted : 29 November 2018 22:56:33
The next step was to increase the surface area of the supports for better fixing the wind and spray deflector. For this, i glued small lengths of 1.0mm square strip to each side of the supports.
#507 Posted : 29 November 2018 22:57:51
The attached photo shows the wind and spray deflector panels being added.
#508 Posted : 29 November 2018 22:58:54
The wind and spray deflector completed. All panels filed flush and edges levelled.
#509 Posted : 29 November 2018 22:59:55
View from the front.
#510 Posted : 29 November 2018 23:00:35
Looking from the port side.
#511 Posted : 29 November 2018 23:01:40
From above.
#512 Posted : 29 November 2018 23:04:25
I then started to add some of the PE supplied with the part-works. In this case the brackets that secure the radio lines. The attached photo shows the port bracket in place. The bracket required a bit of modification due to the change in shape of the conning tower to get it to sit correctly.
#513 Posted : 29 November 2018 23:05:10
Starboard bracket.
#514 Posted : 29 November 2018 23:06:24
This PE frames the foghorn.
#515 Posted : 29 November 2018 23:07:11
Another piece of PE attached.
#516 Posted : 29 November 2018 23:09:11
That concludes this weeks update.
Thanks for looking in and your comments. Have a great weekend and happy modelling!BigGrin
#517 Posted : 30 November 2018 00:32:20
Looking excellent Phil.Cool
#518 Posted : 30 November 2018 01:11:16
Looking fab, great example of some scratch building.....Drool Drool .. Very well done...
#519 Posted : 30 November 2018 07:10:27
Hi Phil,
Lovely update as always.
#520 Posted : 30 November 2018 07:31:57
This page was generated in 0.577 seconds.
