R2d2 mainboard Options
luigione
#1 Posted : 26 November 2018 13:04:31
I'm assuming that the operating system for R2D2 will be preloaded on the mainboard. From what I can see from the photos, the mainboard seems to be a variant of an Orange PI zero,will a backup of the operating system be made available in case of corruption?
kombat
#2 Posted : 26 November 2018 13:33:59
Rank: Newbie
it s a Orange Pi Zero Plus 2 H5
Technical Specs:
H5 Quad-core Cortex-A53
Mali450 GPU
512MB DDR3 RAM (shared with GPU)
Micro SD/TF card (Max. 32GB) /eMMC flash(8GB)
WiFi/BT: AP6212, IEEE 802.11 b/g/n,BT4.2
A CSI input connector Camera, Supports video capture solution up to 1080p@30fps
Supports HDMI output with HDCP, Supports HDMI CEC, Supports HDMI 30 function
26 Pins Header, compatible with Raspberry Pi B+
13 Pins Header,with 2x USB, IR pin, AUDIO(MIC, AV)
1x USB OTG (also used as power input)
Power and status LEDs
TTL level UART for debug
Supported OS:Linux Android, Ubuntu, Debian, Raspberry Pi Image
Dimensions 48 mm × 46mm
Weight: 36gr
This page was generated in 0.129 seconds.
