80 Pages «<2324252627>»
#481 Posted : 20 November 2018 16:22:45
DaDokta wrote:
Superb work as always! Great build!
Thank you very much Walter!BigGrin Cool Your comments are appreciated!
#482 Posted : 22 November 2018 21:12:19
This week started off by deciding to improve the look of the port armoured box by increasing the taper on the bottom of it and adding a further taper to the top. The look of it now is much improved in my mind and more in keeping with the b/w photo I posted last week showing the side of U230's port armoured box.
I also added filler to the radar mast housing and spent a bit of time blending that in once dry.
#483 Posted : 22 November 2018 21:18:22
I then constructed a lid for the box as I figured what was the point in having something to protect you if it has an open top, especially if they were designed to protect the lookouts from aircraft gunfire? I have spent plenty of time researching but could not find any photos of a U-boat fitted with armoured boxes shown from above, which was pretty selfish of them really not to think that modellers in the 21st century would want these pics!LOL
#484 Posted : 22 November 2018 21:20:05
From another angle.
#485 Posted : 22 November 2018 21:21:30
I then turned my attention back to the starboard armoured box and continued to fabricate the tapered sides to make up the box section.
#486 Posted : 22 November 2018 21:22:33
Side panel fitted.
#487 Posted : 22 November 2018 21:23:13
Side view.
#488 Posted : 22 November 2018 21:24:16
Starboard armoured box, looking from the rear.
#489 Posted : 22 November 2018 21:25:37
Front view.
#490 Posted : 22 November 2018 21:26:40
The attached photo shows the underside of the starboard armoured box and the way it tapers into the conning tower.
#491 Posted : 22 November 2018 21:35:53
That completes this weeks update and also sees the completion of the armoured boxes. Admittedly a bit of the filler work needs dressing with a file and sanding stick but that will only take a few minutes.
Next week I can move on to the next stage of modifying the conning tower with the addition of a wind and spray deflector. As it stands, the part-works supplied version of U96 represents an earlier version that was straight, whereas my model of U230 dating from 1943 was retro-fitted with an improved version with a more pronounced taper. As was common with U-boats, improvements were introduced continuously during the war and the wind and spray deflector was one of them.
Until next week, thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
#492 Posted : 23 November 2018 00:37:34
Looking fab, another great update.....Drool Drool
#493 Posted : 23 November 2018 07:40:50
Thank you Alan!BigGrin The armoured boxes seemed to take forever to build, what with limited resource material and their angular profile, but now i can move onto the next stage.Cool
#494 Posted : 23 November 2018 08:39:37
Great update, you do like a challenge.
#495 Posted : 23 November 2018 08:55:50
LOL Thank you Mark! You could say that. I sometimes question my own sanity whilst on this project.Flapper
#496 Posted : 23 November 2018 09:17:52
Another incredible update!
#497 Posted : 23 November 2018 10:39:42
Thank you very much Walter!Cool BigGrin Your HMS Victory build is also an incredible model!
#498 Posted : 23 November 2018 15:20:27
This is an epic build and will result in a stunning completed U-boat.
#499 Posted : 23 November 2018 17:33:15
Thank you Al for your kind words!BigGrin Cool With fingers crossed i hope to complete this project by the end of 2019. I say fingers crossed as I have a multitude of scratch building ahead of me and that always takes longer than you think.Blushing
When it's done, I intend to turn my hand to modelling something less complicated and time consuming.Blink
#500 Posted : 29 November 2018 22:47:43
This week I started off by making the wind and spray deflector which sits along the front edge of the conning tower.
I started off by cutting evenly spaced slits around the edge of the conning tower with a razor saw. See attached photo.
Guest (6)
This page was generated in 0.398 seconds.
