12 Pages «<101112
Pete's R2 build Options
Ritchie69
#221 Posted : 20 November 2018 21:11:04
The last but 1 delivery. Not long now until the end of the build. BigGrin
Issue 94
In this issue we get the microcontroller unit, cable clips & screws.
Attach the cable clips to the microcontroller. Then slid the microcontroller into the body of R2 and fit the lugs onto the circuit board bracket.
Ritchie69 attached the following image(s):
Completed - R2D2
Ritchie69
#222 Posted : 20 November 2018 21:21:49
Issue 95
In this issue we get the head bearing, dome chassis parts & fixing parts.
Insert the small bearing into the dome drive shaft and secure with the bearing retainer. Insert the large bearing into 1 half of the bearing housing. Put the 2 bearing housing halves together, and slide the cable retainer over the screw holes ans secure them all together.
Completed - R2D2
Ritchie69
#223 Posted : 20 November 2018 21:34:12
Issue 96
In this issue we get the dome motor, dome motor cover & wiring.
Clip the motor cover onto the motor. Then connect the wiring.
Take the support plate, bearing housing & drive shaft from issue 95. Attach the dome motor and support plate together, then the bearing housing. Slide the drive shaft assemble into the bearing housing.
Completed - R2D2
#224 Posted : 20 November 2018 21:42:35
Looking good, not far to go before he is running around.
#225 Posted : 20 November 2018 23:05:21
BigGrin Coming together nicely and looking goodCool
#226 Posted : 21 November 2018 00:05:55
Looking good, final stages.Cool
Ritchie69
#227 Posted : 21 November 2018 19:50:38
Thanks all.
Couple more weeks and he will be moving around the house, I can’t wait. Woot Woot Woot
Completed - R2D2
Ritchie69
#228 Posted : 31 December 2018 22:35:41
This is it, we have finally reached the end of the build.
Issue 97
In this issue we get some cable ties, the camera, a lens & cable lables.
Take the cable lables and seperate them from the sprue ( I decided to high-light the letters on each cable lable to make it easier to read). Attach them to the wires at the end of the cables.
Insert the battery box into the bottom of the base & connect the wires, make sure once everythng is connected this can be removed easily.
Start to connect all the cables to the various boards inside R2. When connecting the cables to the boards, make sure that all the pins are straight and the connectors are fully in. Use cable ties and the clips on the MCU to keep the wires neat.
Completed - R2D2
Ritchie69
#229 Posted : 31 December 2018 22:56:25
Issue 98
In this issue we get 2 brackets for the dome circuit board, screws & washers, lens cover seals, sensor housing & buffers & ultrasound sensor cover.
Take the camera from the previous issue and remove the protective cover from the front & back. Feed the ribbon connector through the hole in the camera mount (make sure you don't twist or kink this). Secure in place with 2 screws. Stick the 2 lens cover seals at the base of the hole in the dome. Remove the old lens from the blue faceplate and replace with the new lens. Then fit it into place on the dome.
More cables need to be label's with the cable label's, then attach the ultrasound cover. Take the front panel of R2 and attach to the body frame, making sure the cables are fed through carefully. Then connect the cables to the boards.
Replace the sensor stop with the sensor housing & buffers. Attach the dome motor assembly and connect the wires. Take the pivot support and attach to the dome.
Completed - R2D2
Ritchie69
#230 Posted : 31 December 2018 23:13:45
Issue 99
In the issue we gat the dome circuit board.
Remove the cover from the dome circuit board. Attach the 2 brackets from the previous issue to the circuit board. Then fit to the inside of the dome. Then take the camera ribbon and insert into the circuit board, then insert the mic cable.
Completed - R2D2
#231 Posted : 31 December 2018 23:22:00
To be honest Pete, I’m excited for you Drool
Looks the biz ThumpUp
Really good diary, by the way
Regards Gray
Ritchie69
#232 Posted : 31 December 2018 23:34:50
Issue 100
In this issue we get the mains adaptor, 2 cables, extension cable, cable tidy, plugs & a sticker.
Take the extension cable and insert into the MCU. Then take the 2 cables and attach the cable label's onto them and twist the cable tidy around them both. Insert the cables in the 2 circuit boards in the dome then use a cable tie to secure them to the pivot support. Insert the spindle from issue 96 into the dome then feed the cables down the centre of R2's body. Turning the dome over and guiding the spindle down the drive shaft.
Insert the cables into the MCU, and secure with a cable tie to the motor bracket.
Connect the speaker cable to the back panel, then offer it up to the frame and secure with screws. Insert the plugs (I have left these off until R2 is fully working). Take the sticker and peel backing off and open up the right hand door and attach sticker.
I am still waiting on the batteries so will post a final post once R2 is fully working.
Completed - R2D2
#233 Posted : 01 January 2019 09:57:56
Great work Pete, excellent diary throughout the build.
Look forward to seeing him in action soon.
#234 Posted : 01 January 2019 11:00:49
BigGrin Great to see another R2 finished and nice workCool
Ritchie69
#235 Posted : 01 January 2019 11:52:51
Thanks Gray, Mark & Andy, for your comments. BigGrin
I’m glad you have enjoyed my diary. ThumpUp
I’ve really enjoyed this build and also can’t wait till he is moving around the house.
Thanks all for the support i’ve been given.
Peter
Completed - R2D2
Ritchie69
#236 Posted : 28 April 2019 11:35:40
So after waiting for 4 months for DeAgostini to sort out the batteries, Angry I decided enough was enough.
I ordered 6 batteries from 18650.uk and proceeded with charging them up. It took a while but I finally got there.
I installed the batteries and moved R2 onto the floor before starting the process of activating the batteries.
Then with fingers crossed I powered him up, and pressed the on/off button.
To my surprise, the red light came on he juried forward and then moved his head right then left then back to the centre.BigGrin
I then connected R2 with the app and tested all controls and movements, all worked fine.
I now have a fully working R2D2 unit.ThumpUp ThumpUp ThumpUp ThumpUp
Completed - R2D2
#237 Posted : 28 April 2019 12:15:46
That's great to hear, well done on completing the build.....Cool Cool .. Now have fun with him.....BigGrin BigGrin
12 Pages «<101112
This page was generated in 0.475 seconds.
