Issue 54 mast diamiter Options
Foz
#1 Posted : 14 July 2011 17:14:36
Hi
Just a quick question regarding the mast size from issue 54. The dowel suplied in this issue is 8mm diamiter and we are ytold to use that for planking around the mast holes.
When we did the upper gun deck planking it said to use the dowel from issue 41 which is larger at 10mm diamiter, so we now have 2 different size holes in the upper gun deck and the quarter deck.
Is this correct?
Thanks
Foz
Son of Bulwark
#2 Posted : 14 July 2011 17:41:11
Hi Foz! Cool
The fore mast and main mast uses 10mm dowels the mizzen mast has a 8mm dowel for the mast. So use the smaller dowel on the aft hole only and the other dowel for the other two holes.
Foz
#3 Posted : 14 July 2011 18:10:03
Thanks very much darren, i will now continue without worrying if i have the wrong size holes.
Foz
This page was generated in 0.133 seconds.
