Official Standart Build Diary - Pack 1 Options
#1 Posted : 20 November 2018 16:11:02
Imperial Russian Yacht - Standart
The Standart was an Imperial Russian yacht serving Emperor Nicholas II and his family, being in her time (late 19th/early 20th century) the largest Imperial Yacht afloat. After the Russian Revolution the ship was placed in drydock until 1936, when she was converted to a minelayer. During World War II, she participated in the defence of Leningrad.
The Standart was built by order of Emperor Alexander III of Russia, and constructed at the Danish shipyard of Burmeister & Wain, beginning in 1893. She was launched on 21 March 1895 and came into service early September 1896.
Standart was fitted out with ornate fixtures, including mahogany panelling, crystal chandeliers, and other amenities that made the vessel a suitable floating palace for the Russian Imperial Family. The ship was manned and operated by a crew from the Russian Imperial Navy. During the reign of Nicholas II, Standart was commanded by a naval Captain, although the official commander was a Rear Admiral. Her commander in 1914 was Nikolai Pavlovich Sablin.
In 1907, Standart ran aground on an uncharted rock off the Finnish coast. Although damaged, the ship did not sink and was repaired and soon returned to service. The Russian Imperial Family was vacationing on the Standart during the summer of 1914, when they received the news of the assassination of Archduke Franz Ferdinand, in Sarajevo. With the outbreak of World War I, Standart was placed in drydock.
Following the fall of the Romanov Dynasty, Standart was stripped down and pressed into naval service. The ship was renamed 18 Marta (18 March), and later Marti.
In 1932-1936, Marti was converted into a minelayer by the Marti yard in Leningrad. During the Second World War, Marti served in the Baltic, laying mines and bombarding shore positions along the coast. On 23 September 1941, Marti was damaged in an air attack at Kronstadt, but later repaired and continued service until the end of the war. A mine laid off Hanko by Marti sunk the German submarine chaser UJ.117/Gustav Kroner on 1 October 1941.
After the war, Marti was converted into a training ship and renamed Oka in 1957. She continued serving in that role until she was unceremoniously scrapped at Tallinn, Estonia, in 1963.
The Standart Model
The Standart model was created exclusively for DeAgostini ModelSpace in co-operation with Federal State Budgetary Institution of Culture and Art "Central Naval Museum" of the Ministry of Defence of the Russian Federation. This graceful model, like its original, is a model of marine elegance and the model reproduces all the features of a real yacht.
https://www.youtube.com/watch?v=k8Q0sgsmRDY
Scale: 1:130
Length: 104cm
Width: 17.5cm
Height: 40cm
Hull Structure: Hull (timbers, false keel and reinforcements) made of black poplar wood, laser-cut 5mm boards. Decks, side walls, cabins, booths and other similar parts made of black poplar wood, laser-cut 3mm boards. First planking: ramin wood strips (2mm). Second planking: ramin wood strips (0.6mm). Deck planking: ramin wood sheet (3mm). Ramin wood strips of different sizes for miscellaneous decorative elements.
Decorative parts of the hull, cabins and booths: Spin-cast & Die-cast metal portholes, anchors, screws, guns, belaying pins, vents, boats, prow and stern decorative elements, figurehead, funnels.
Photo-etched Brass ladders, railing posts, door and window frames, gratings, among others.
Other materials (brass, iron, plastic) - Chains, decorative elements, spikes, grating beeches, eyepins, brass thread, glazing.
Masts: Sapeli wooden Masts & Spars. Polyester rigging threads (ratlines, ropes, lifts, etc). Cotton pre-sewn sails. Boxwood pulleys. Paper fabric printed flags.
Pack 2 also contains a keel jig/workstand kit.
Clear, step-by-step English instructions (via download), accompanied by detailed photos to make building your Standart model, as easy as possible.
On sale here: https://www.model-space....the-yacht-standart.html
Optional extra's
Lighting: The LED hull lighting kit will be available in the ModelSpace online shop.
The display stand will be available in the ModelSpace online shop.
#2 Posted : 24 November 2018 20:37:19
Imperial Yacht Standart Pack 1, Stages 1-5.
Stage 1
Stage 1 contents:- Forward false keel ,frame, figurehead, bow decoration, glue, sandpaper and a brush.
I have used the ModelSpace build stand for the Pack 1 stages of the build. This is not a nessassary item I have used it for display purposes.The build stand can be found here.
https://www.model-space....stand-san-felipe-1.html
Pack 2 contains a keel jig as part of the assembly.
Take the false keel and the frame and sand them smooth. Check the fit of the frame into its slot on the false keel and adjust the fit if needed. When you are happy with the fit glue frame 5 into the 5th slot on the false keel making sure it is at a right angle to the keel.
Next take the bow decoration and paint it matt black. When it is dry take some gold paint and dry brush the raised areas of the bow decoration. I then painted the figurehead gold with a dark wash to bring out the high lights.
Stage complete.
Store any unused parts in a labelled bag for future use .
#3 Posted : 24 November 2018 20:44:01
Stage 2
Stage 2 contents
:- Frames, launch, launch fittings and an anchor.
Take the four frames and sand them smooth then check there fit on the false keel then glue them in place.
Now take the launch and smooth its sides and any other cast metal parts. Remove the rudder from the etch sheet and glue the rudder to the stern of the launch then paint the outside of the launch white and the inside black. When dry mask off the lower part of the hull and paint the upper works with a copper paint. Take the boiler and chimney paint it copper and when dry dry brush it with black paint. Stain the wood strip and add the benches to the launch along with the boiler then cut a screw from the etch sheet paint it black and glue it just in front of the rudder.
Glue the anchor stock to the anchor and then paint it matt black.
Stage complete.
#4 Posted : 24 November 2018 20:46:28
Stage 3
Stage 3 contents
:- Second false keel, frame, reinforcements. Bow decoration and propeller parts.
Take the frame and false keel and smooth them with sandpaper then check that the frame fits into its slot. Glue the frame onto the keel making sure it is at right angles to the keel then take one of the reinforcements and glue it to one side of the keel, forward of and against the frame just fitted.
Clean up all the metal parts then paint the propeller with bronze paint. Take the decoration and paint it matt black then dry brush it with gold paint like you did to the other decoration.
Stage complete.
#5 Posted : 24 November 2018 20:48:54
Stage 4
Stage 4 contents
:- Frames, lower deck, wheel and stern crest.
Take the frames clean them up and test fit them behind the last frame fitted to the false keel then glue them in place making sure they are at right angles to the keel.
Next take the bow section of the false keel and test fit the lower deck to it, when it fits glue the deck in place. Again I opted here to paint the crest gold and add a wash like I did with the figurehead.
Now take the wheel and crest and clean them of any burrs. Paint the wheel brown and then use gold paint on the inner and outer rims of both sides. Take the crest and paint it gold then bring out the detail with a dark wash.
Stage complete.
#6 Posted : 24 November 2018 20:51:13
Stage 5
Stage 5 contents
:- False keel, lower deck, reinforcements and a davit.
Take the two keel assemblies you have made and glue both together then use a reinforcement plate to cover the joint, clamp the joint together and leave to dry. When the keel section is dry take the second lower deck and test fit it to the keel and then glue it in place.
Remove any burrs from the davit and then paint it white.
Stage complete.
This page was generated in 0.455 seconds.
