Front wheel spacers Options
Skiddy
#1 Posted : 14 July 2011 12:44:16
Just fitted the plastic spacers to the wheels ( step 13 )....easy !
Instructions say not to mix the two pairs ??? you have to or you will get two lugs on the outside and two on the inside of the rim. Maybe it should read don't mix the front and rears ?
Words of wisdom from an amateur Confused
davyp1
#2 Posted : 15 July 2011 00:42:38
Red Medal: Red Medal
No.Huh
andyone
#3 Posted : 15 July 2011 18:07:44
Rank: Amateur level 2
Mine seem ok, could you post a picture to show us in more detail.Confused
Skiddy
#4 Posted : 15 July 2011 18:45:51
Just checked the rears and seem fine as a pair off the sprue. Have put the fronts together so don't know if I was having a moment or not Confused
