19 Pages <1234>»
tf64 Stage Coach Build 1848 Options
#21 Posted : 19 November 2018 10:47:25
Hi Alan,thanks for having a look this kit is different but again you have to think about what you are doing with some of the wood as they are very thin and will split they tend to follow the grain but a great kit for the money.
Trev
#22 Posted : 19 November 2018 10:50:43
Hi Ken, thanks for having a look, i think you would like to build this one plenty to think about.
Trev.
#23 Posted : 21 November 2018 08:28:26
UPDATE:21.11.18.
Hi all again small update this is about the haul bar which is part of the steering assembly tried to follow as instructions so this is how i made it.
This is the haul bar with brass fitting.
Looking at the drawings i found that the best way was to make up a pattern by hand and glue it to the bar and work from there.
#24 Posted : 21 November 2018 08:34:13
Next was to file down to shape.
Then remove pattern.
Happy with the shape the next job was to fit the brass around the end,this will be pinned and glued.
Thanks for looking,
Trev.
#25 Posted : 21 November 2018 09:08:55
Nicely done Trev, neat and tidy work as always....Cool Cool
#26 Posted : 21 November 2018 18:42:22
Hi Alan,
Thank you for looking in and your comments,looking forward to the next part to build this will be fitting the steering struts and making the haul pin from solid brass plus the bar and brake shoes.
Trev.
#27 Posted : 24 November 2018 17:29:13
Hi all,today I have worked on two parts first primed all 4 wheels,second started work on the rear axles and stabilizers beams.
Just a short update more soon
Trev.
#28 Posted : 24 November 2018 18:54:53
Nice clean build TrevBigGrin looks good.
#29 Posted : 25 November 2018 00:03:39
Very nice progress Trev, looking good....Cool Cool
#30 Posted : 25 November 2018 18:02:36
Hi very nice start ,look forward to following your progress ,cheers mick.BigGrin
#31 Posted : 25 November 2018 20:16:09
Thanks for your comments AL,next wil be the haul post that looks fun.
Trev
#32 Posted : 25 November 2018 20:19:17
Alan,looking forward to the next part which will be the haul post,more soon.
Trev
#33 Posted : 25 November 2018 20:21:35
Mick,thanks for looking at my work, more soon,I see your builds have grown.
Trev
#34 Posted : 27 January 2019 15:36:28
Hi,this week I gave the wheels a rest and moved on to the coach work,looking at the parts they needed sanding before fitting,the main point was to try and keep everything square,have a look more to follow.
Trev
#35 Posted : 27 January 2019 19:07:23
Nice update Trev.
That looks like some very neat work.
Cool Cool Cool
#36 Posted : 27 January 2019 21:46:05
Nicely done TrevBigGrin it will feel a lot stronger once you have the base/sides on.
#37 Posted : 27 January 2019 21:57:27
thanks Derek.
Trev
#38 Posted : 27 January 2019 22:02:13
Hi Al,
Thanks for that tip it did seem a bit week, find out more during the week.
Trev
#39 Posted : 27 January 2019 23:41:02
Now that does look nice Trev, beautiful work....Cool Cool Cool
#40 Posted : 28 January 2019 08:03:43
Finding this a great kit to work with I am surprised that there are not a lot more building it.thanks for looking in Alan.
Trev.
19 Pages <1234>»
This page was generated in 0.190 seconds.
