Issue 96 screws Options
RebelRebel
#1 Posted : 18 November 2018 08:08:25
Rank: Newbie
In Issue 96, the instructions state to use 12mm screws when fitting the drive motor case. I don't have any of this size somehow so although I can get them online, there seems to be a 'M'code which I assume is a sizing thing?
Can anyone help me please with which M 12mm screws I should be ordering?
Thanks
Magical Barrie
#2 Posted : 18 November 2018 08:25:33
Rank: Beginner Level 3
Hi! In the official build diary it says that's mistake in the magazine, here's what you need to use ☺
Note
The instructions on page 14, stage 13 tell you to use 3 x 12mm screws to attach the bearing housing. The correct screws to be used are the 2 x 6mm screws provided in stage 94.
RebelRebel
#3 Posted : 18 November 2018 08:48:49
Rank: Newbie
Note
Thank you. I shall try 6mm screws later.
This page was generated in 0.081 seconds.
