Hi guys,
in the past i`ve ordered a bunch of full kits and delivery to Austria was not a problem.
But now Austria is not on the list of selectable countries!
Is there any reason for that?
And most of all - how do i now get my Sopwith Camel which should be under the Christmas tree in a month??? :)Greetings, Walter
It should be but we have a bug in the International system.
You can order to your address but just select “United Kingdom” as the country and the dispatch dept will organise to be sent to you - don’t forget that you will also need the woodgrain template for the Sopwith.
If it helps, Sopwith Camel will also be sale in DE very soon and could order via the German ModelSpace site if you wish.
Thanks for the information Tomick!Greetings, Walter
