HKModels 1/32 Lancaster ground accessories Options
ALW
#1 Posted : 14 November 2018 14:47:45
Hello all
Not long now until my eagerly anticipated 1/32 Lancaster arrives!
I note in one of their (HK Models) promotional photos next to the completed model
set around a diorama are 1/32 service vehicles.
Does anyone know where I can get a 1/32 WW2 refulling truck and maybe other
same scale vehicles?
I've had a look but can't seem to find any!
Thank you.
Regards.
ALW
#2 Posted : 14 November 2018 15:57:54
Thank you.
Still not a long a wait as we've waited already! BigGrin
#3 Posted : 15 January 2019 10:15:44
Signifier Avation Kits have a 1/32 WW2 RAF Power Cart
https://www.scalemates.c...ower-cart-wwii--1175517
ALW
#4 Posted : 15 January 2019 10:17:36
This looks like a must have
#5 Posted : 15 January 2019 10:21:59
ALW
#6 Posted : 15 January 2019 10:23:45
Cheers Tom
Will have a proper look when I get home!
#7 Posted : 15 January 2019 10:26:26
And PJ Productions have a 1/32 RAF ground crew fig to go with it
https://www.1001modelkit...sw1DEAQYASABEgLpXfD_BwE
#8 Posted : 23 January 2019 21:12:29
IconicAir now also have a:
1/32 Cookie Bomb Trolley
http://www.iconicair.com/cookie/
Upkeep Bomb Trolley
http://www.iconicair.com/dambuster/
and a Field Tractor is on the way too Cool
and the Dambuster conversion set
http://www.iconicair.com/hkmd/Index.html
(though if you want to also display the engine of the HK Lanc, it’s not the correct Merlin engine type for that of the Dambuster variant which had a Packard Merlin).
ALW
#9 Posted : 23 January 2019 21:14:46
Thanks Yom
That’s great news. I’ll get those ordered!
Regards.
#10 Posted : 23 January 2019 21:23:15
ALW wrote:
Thanks Yom
Regards.
Be mindful that if you go the Dambuster route, the Dambuster Lancaster had the Packard V-1650-1 Merlin 28 but the HKM Lanc kit has a Merlin XX - slightly different engines and I don’t think the Packard has the RR rocker cover nameplate.
Other elements of the HKM Lanc also need to be converted to make it a Dambuster, such as the fitting of front gunner stirrups to keep his feet out of the bomb aimers face, spent case collecting bags (to stop them falling on the bomb aimers head) and strengthened oleo legs and bomb beams.
#11 Posted : 23 January 2019 21:25:05
Upkeep kit is no use on the HKM kit as its a MkI-B and the 617 Lancasters were MkIII 'Specials'. Biggest issue is wrong engines!BigGrin
ALW
#12 Posted : 23 January 2019 21:25:39
Thanks for the additional info
#13 Posted : 23 January 2019 21:26:44
Also, the nose blister is to small, it was larger on the MkIII.
#14 Posted : 23 January 2019 22:59:32
That’s incorrect, the HKM kit can be built as a B Mk.I or a B Mk.III and contains both nose blister types - The Dambuster Lanc’s were B Mk.III Specials (Type 464 Provisioning), therefore the HKM kit has the Mk.III blister of the Dambuster.
#15 Posted : 23 January 2019 23:29:11
I stand corrected, it is in the kit.
#16 Posted : 24 January 2019 15:37:58
Apparently the HK Lanc kit also includes the option of the mid upper turret blanking plate that’s used on Dambuster variant.
This page was generated in 0.124 seconds.
