5 Pages 123>»
Artesania Latina Sopwith Camel build. Options
#1 Posted : 11 November 2018 19:36:30
BigGrin Hi All
Made a start on this today, you begin by making up the fuselage jig by adding the tail piece and then two stringers are added to the bottom of the jig to give strength and support. I will be using stain on the wood parts instead of painting them to look like wood. Next the two wing spars are added after some etch sheathes were added followed by the rest of the fuselage formers and more jig supports.
The cast metal fire wall was cleaned up and painted and then inserted into the forward part of the jig. Next the upper jig is added to square the top to the bottom. The four fuslage corner stringers were next added by inserting them into the pre-cast holes in the fire wall and the cut outs at the tail. Once everything was checked to be true the stringers were glued to the formers.
More strengtheners were added to the cockpit area along with more etch parts. Next the forward tailplain was made up with the ribs being added first then the etch leading edge and finally the trailing edge made from 1.5mm wire.
The instructions now start to assemble and paint the cockpit fittings like the joy stick, control elements and the pilots chair which is assembled from 4 parts. The oil and fuel tanks are also assembled here as you see there still being prepared for painting/
More soon.
#2 Posted : 11 November 2018 19:45:25
Nice start Andy, certainly looks a great kit.
#3 Posted : 11 November 2018 19:58:39
BigGrin Now this looks a stunning kit Love nice start Andy
Martyn
#4 Posted : 11 November 2018 20:23:32
Great start Andy. Cool Cool
The jig system looks like a fine addition to create a wonderful model. I got to see the kit contents close-up at Telford today and the parts look top quality.
Looking forward to the next update.BigGrin
#5 Posted : 11 November 2018 23:28:27
Very nice Andy, off to a great start....Cool Cool
#6 Posted : 11 November 2018 23:28:43
Quick off the blocks with this one. Very nice start, looking great. Can't wait for mine to arrive.
#7 Posted : 11 November 2018 23:35:49
BigGrin Thankd for looking in and your comments everyoneCool
#8 Posted : 13 November 2018 20:41:14
BigGrin Hi All
The upper jig is now removed having done its job and things start getting added to the cockpit. Spending time preparing the cast parts here removing burr/casting lines improves the look of the parts before painting can commence.
The first parts added are the fuel tank, main control bar and the joystick is in turn glued to this bar. Next the magnetto's are added to the rear face of the firewall along with the carburetta tube.
The two foot plates were added next then the chair had the seatbelt's added and then fitted into the cockpit. The seatbelt tethering lines were next tied in place. Various instruments were made up and added around the cockpit seat/sides. Still more to be added here.
More soon.
#9 Posted : 13 November 2018 21:43:28
The more i see this build progressing, the more impressed i become with the kit Drool
Great build Andy ThumpUp
Gray
#10 Posted : 13 November 2018 22:44:06
Now in know what the Christkind has to bring next month!
Great build!
#11 Posted : 14 November 2018 04:44:48
Looking fabulous AndyCool this will look great next too the Fokker.
#12 Posted : 14 November 2018 08:04:16
BigGrin Thanks for looking in and your comments everyone.
@Walter, its a great kit to build and one you will enjoy buildingCool
#13 Posted : 14 November 2018 09:05:25
Nice work Andy, great kit.Love
#14 Posted : 14 November 2018 16:15:07
Very impressive Andy, Christmas can't come quick enough to get my hands on mine.
#15 Posted : 14 November 2018 19:36:44
#16 Posted : 15 November 2018 21:17:46
Cool Great start Andy look forward to seeing your progress. BigGrin
#17 Posted : 16 November 2018 07:03:20
Well this is a great kit Andy and in skilled hands to looking forward to seeing more.
Trev.
#18 Posted : 16 November 2018 07:36:01
BigGrin Thanks for looking in and your comments both of youCool
#19 Posted : 16 November 2018 10:45:13
Lovely looking kit Andy and you have made a superb start.
#20 Posted : 16 November 2018 20:51:52
BigGrin Thanks for looking in and your comments PhilCool
5 Pages 123>»
This page was generated in 0.202 seconds.
