FightingWillie Options
FightingWillie
#1 Posted : 11 November 2018 19:57:05
Rank: Amateur Level 1
Good day everyone:
I have come across a situation that I am not sure if should be worried about or not. In the center of the ship I have developed a 1 MM gap open up on my planking. I have the same gap on both sides. I can easily push it down and I know that the tops of the ribs will be trimmed. I watched the video and it did not look he had that gap. What do you think?
FightingWillie attached the following image(s):
#2 Posted : 11 November 2018 22:12:21
Hi there Willie!
Personally I wouldn't worry too much, if you can push it down easily do that and pin and glue. The planks normally follow the curve of the hull rather than going completely straight and level and with all double planked hulls, its the second finishing layer that counts more.
Robin.
FightingWillie
#3 Posted : 11 November 2018 22:43:11
Thanks for the help this is my first at wooden ship so I real don't know what to respect.
#4 Posted : 11 November 2018 23:22:45
All looking good, very neat and tidy. As for the plank, you can push it down, pin and glue. I don't see it causing you a problem....Cool Cool
FightingWillie
#5 Posted : 12 November 2018 00:05:35
Thanks, I going to start a build diary here shortly.
This page was generated in 0.111 seconds.
