 Coming together nicely Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Coming on nicely Roy. Mark Regards Markwarren (Mark) Admin
looking very nice, seems you are a few in front of me at the moment.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,190 Points: 15,719 Location: ipswich
Just a small update today. The final wheel has been assembled now and is fitted to the rear axle. It all went together very easily and I'm looking forward to seeing how it will all go together with the main body... roymattblack attached the following image(s):
 Looking good and nicely done Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks good Roy Al
Nice update Roy, looking good. Mark Regards Markwarren (Mark) Admin
Looking fab Roy, top class work as usual.... Regards Alan
 Rank: Pro     Groups: Registered
Very nice work Roy! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I've done a little more on this one today - the Citroen van is driving me nuts... I decided to remove all the screw fixings on the tailgate panel and just have it smooth and leather covered. The two large fixing posts on the lower inside of the metal door panel had to be ground down flat using a bench grinder. The raised fixing points on the inner panel were cut off and the part covered in leather. Without screws, it meant everything had to be glued together with CA. Not a problem but obviously care was needed. The rear screen was fixed to the frame with D/S tape first just to keep it all together. It was then glued into the door panel. After that, the inner panel was glued in place. Depending on if anything yet to come covers the hinge fixings, they will all be painted to match the leather. Quite happy with the result... roymattblack attached the following image(s):
Looks good Roy Al
Thanks Al. A tad fiddly but worth the effort.
Roy.
Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Great idea to loose the screws Roy, end result looking good. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
Hi looking good Roy,I'll be carpeting and leather trim mine so be pinching some your methods on this, cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Joined: 18/11/2017 Posts: 17 Points: 41 Location: Fleet, UK
Roy, I got the rear door parts yesterday and already decided to get rid of the screws - sometimes DeAg's determination not to use glue makes for some rather clumsy assemblies! I am not using leather so will have to fill the holes.
The door parts arrived in a gigantic box containing the bodyshell - starting to get exciting now. Next it says the engine subframe will be attached to the bodyshell - at last!
Very neat job on the rear door Roy. Looks great.
Due to excessive handling I think, the chrome strips on my bonnet top edges were losing shine and even the paint in several places. A couple of strips of Tamiya tape, a Molotow chrome marker pen... Voila. All sorted. roymattblack attached the following image(s):
Moving along nicely now. The headlining as supplied doesn't quite go with my revised colour scheme so I decided to change it to a much lighter cream. All very straightforward - repaint the entire part first, and then fit a self adhesive panel to the centre. Much brighter and a bit more prototypical. Next task - cover the door sill panels with leather, add a chrome edge strip and then fit it all in place. I also added some metal foil to the lock striker plates. Again, quite straightforward. The leather here made no difference to being able to fit or shut the doors. I'm aware that the added leather on the sills and seats might make fitting everything together at the end a bit tight, but we'll see how it goes. Roy. roymattblack attached the following image(s):
Hi looking good ,the leather looks great,cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
