Here is my Entry into the "Last Year of the Panavia Tornado" competition I have ordered the 1/32 Gulf war Tornado awaiting delivery. Also i have the White metal undercarriage and the Tornado book. I have managed to get hold of the Old Flightpath Gr1 set not the conversion set. Chris
magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Look forward to seeing your Tonka Chris  good luck in the comp. Al
Looks a very interesting build. Good luck in the competition Gray
Wow, looks like there`s gonna be more brass than plastic. Should result in a fine build, just mind your back when you pick it up. Good luck in the comp. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Very nice Chris, this is going to be a very interesting build to follow.... Good luck with your entry…. Regards Alan
Great to see a Gulf War variant in the competition mix; good luck with the entry
 Some nice stuff there Chris and good luck in the comp Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Lovely kit Chris, good luck in the competition. Mark Regards Markwarren (Mark) Admin
Nice looking aftermarket parts you've got, should keep you busy. Good luck with the comp.
Joined: 25/03/2011 Posts: 1,027 Points: 3,075 Location: Lincolnshire
delboy271155 wrote:Wow, looks like there`s gonna be more brass than plastic. Should result in a fine build, just mind your back when you pick it up. Good luck in the comp. Regards delboy271155 (Derek) I was thinking the same thing Derek  Seriously though thats a great set of aftermarket parts you've got there Chris. About the book, I've noticed some of the other chaps have got this as well, is this the most comprehensive book out there for the Tornado? Have fun with your build.
Cheers Guys. Thanks for the encouragement.
The book is probably the best source of info on the Tornado with many pictures and Diagrams. Well worth the buy if you are after doing plenty of detail.
Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Quick update, the kit is released and has been dispatched. So hopefully will start her in the next 3 weeks. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Finally I make a start on my first complex polystyrene Plastic kit with upgrades in over 10 years. So have to re-learn my skills again.
I started with the Ejector seats. Well one of them. It took a-lot of filing the white metal bits to get them to fit but I like the look. Some of the parts were wrong in the set. The Air pipes out of the side of the seat were incorrect, they gave me 4 the same not 2 left and 2 right. So I made my own from wire.
I had a few problems with the superglue not sticking. I made half the seat last night, picked it up and it fell apart. Not good. The brass bits weren't holding also the white metal parts weren't either. I roughed some of the bits up they have held up to now.
I then removed the wiring from the bulkheads and replaced with wire. I installed the pedals with the photo etch plates.
Nice start Chris, looking good. I’m sure it will all come back to you. Mark Regards Markwarren (Mark) Admin
Nice start!Greetings, Walter
Very nice start Chris, those seats look rather impressive.
Nice start Chris, the seat looks great.
Nice start, good luck with the competition entry
 Nice start and looking good, by the way most plastic/resin kit parts have a release agent that needs to be washed in warm soapy water to remove it before construction begins its the same with etch parts but they have an oil coating that will need the use of a degreaser so the glue and paint will adhere to them Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Very nice start Chris, look forward to seeing more..... Regards Alan
