All`s fine then! :)Greetings, Walter
Joined: 30/11/2017 Posts: 493 Points: 1,482 Location: South Norfolk
Hi All, Thanks for the good comments. Issue 102 completed:- All centre line stays fitted After they were fitted I spent nearly the whole morning to re-tension all the stays and backstays to ensure that the masts are vertical. To be honest I was struggling a lot, I couldn't get the stays between the main and fore masts set to a good tension (to bear the weight of the main topgallant sail), also keep the fore and main mast vertical and the jibbooms not inclining upwards. At the end I had to remove (were fixed in previous issues) the two threads between the jibbooms and the fore mast because they were pulling the jibbooms up significantly. Now, I got the mizzen mast nice vertical, the main topgallant mast leaning backwards a very tiny bit, and the fore topgallant mast leaning backwards a bit more than the main mast. Currently all the stays between the fore mast and the jibbooms are unfastened, so the bowsprit is straight. (continuation below...) - Main topgallant staysail fitted. There was some uncertainty how the thread A & B should be fed through the brackets, but with Alan's (Gandale) help I managed to fit them. Issue 103 started:- A faulty sail again  , this time the mizzen topgallant staysail ... When I had the other two faulty sails I didn't complain about this one, because I thought that the curve on the long side is normal. But now I see that the long edge should go to the stay, which is obviously a straight line  . Spare part requested from customer service. - I'm skipping the rest of the issue for now to get all the stay tensions correct. Issue 104 started:As I mentioned above, currently I have no connection between the fore mast and the bowsprit, hence the fore topgallant mast is leaning backwards. I'm hoping if I fit all the bowsprit rigging (bobstays and martingales) first, then it will provide enough support for the jibbooms, that when the stays refitted between them and the fore mast, then everything will be pulled back to vertical, also keeps the jibbooms straight. So started to fit the blocks for the bobstays. If anyone has a better suggestion/idea, I'm open for them. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Am sure you'll receive your replacement sail very soon enabling you to finish issue 102.... All looking good and credit to you, very well done..... Regards Alan
Wow Laszlo!
I thought adding the stays and backstays would be a breeze after producing all the masts and yards - but it sounds like the hell of a task keeping everything upright!
Good job anyway!Greetings, Walter
Hello Guys, It was a long day...oh... by the way, I'm on annual leave due to half term, hence the continuous work on the ship. Issue 104 continued:Today I made all the bobstays and martingales. Then hoped for the best. :) Started to tension them one by one, working from the bowsprit towards the tip of the flying jibboom, to make sure that the tension gradually increases on the jibbooms. I applied the tension on them, that at the end the jibbooms bended slightly downwards. Doing this I hoped that after refitting the stays between the jibbooms and the fore topgallant mast, the tension on them will pull the jibbooms back to straigth and the topgallant to vertical (from leaning backwards). Another 1-2 hours of play with re-fitting and tensioning the stays brought the success end condition. Not 100% perfect, because it seems that the mast is stronger than the jibbooms, but close enough. At the end the main topgallant successfully pulled back to vertical, the fore topgallant leaning backwards only a tiny bit, also the flying jibboom inclining upwards a tiny bit, however they are not noticeable, if you're not aware of it.  Done and dusted, all knots sealed. Phew... Back to Issue 103:- Jib was rigged with threads. Then the problems again... I'm not sure if it's only me, but looks like that the sails are not my best buddies... or I just have another weird shaped sail... Fitted the jib to the stay, but it doesn't seem to hang as on the magazine pictures... the lower edge, I guess, should be more or less parallel with the jibboom, but it's far away from it. Therefore if I try to fix threads D to the corner timberheads it makes big "wave" on the jib. I though that I fitted the wrong edge to the stay but double checked the magazine pictures (showing to fit the A, B, C, D threads, also checking the sawing stripes on it), and I believe I hanged on the good way. Any suggestions? gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Lovely work. Mark Regards Markwarren (Mark) Admin
I´m afraid i can`t give you any advice - but apart from the sail everything looks perfect!
I have a question: which knots do you use when trying to get the right tensiion on all the stays? Is there a special one?
Thanks!Greetings, Walter
DaDokta wrote:I´m afraid i can`t give you any advice - but apart from the sail everything looks perfect!
Thanks! Hi Walter, I’m not sure what supposed to use, not mentioned in the magazine, but I use two half-hitches. I set the tension with the first one and secure the knot with the second one. To be honest, it’s quite tricky because I have to hold the first one with a tweezer while securing with the second otherwise the first releases. But after some practice (and swearing) it works for me. I hope this helps to you. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Thanks Laszlo!
I wonder if there is any easier way - but can`t think of one!Greetings, Walter
Hello Everyone, Issue 103 continued:- fitting the mizzen topgallant staysail is parked for now because I'm waiting the replacement sails. They promised to receive it within 5-7 workdays. - another try with the jib... I removed what I've done yesterday and I flipped it over to have the other long edge fitted to the stay. It looks much better, the short edge is nearly parallel to the jibboom. It still sagging a bit after the lower corner tied (even if there is no tension on those threads) but sagging less than yesterday, and the overall fit is much better. - I fitted the flying jib on the same way, it flipped compared to the magazine. It also sagging a bit, but on an acceptable level, I suppose.  Maybe the pros here would call me an evil or sacrilegious because of flipping them over but it seems right for me.  gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
All looking good to me, beautiful work.... Regards Alan
 Looking good and she is coming to life now the sails are going on Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Your build is looking great and the sails look fine, nice job.
Ahoy Shipmates, Thank you for the kind words, much appreciated. Issue 103 continued:- mizzen booms fitted - mizzen fitted and rigged Question:Will the little loop on the upper front corner be used later on, or shall I just tie it to front edge of the sail? (see close picture below) Issue 105 started/completed:- fore sail fitted - parrel added - sail and yard rigged Wow... that was a hard task, I spent two days to complete the fore sail. Hint: I was struggling with the parrel because while I tried to tie one end to the yard, it was keep falling down by its own weight. So I fixed it temporarily to the mast top to keep it in the correct height and central. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
 All looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Great update!Greetings, Walter
Hello All, Another two days gone, another sail fitted. Issue 106 started/completed:- fore topsail fitted - parrel added - sail and yard rigged One of my biggest fear came true during the rigging... one of the pin on the cockpit pinrail snapped off. I had one snapped already just by fitting them to the deck, now another one snapped during rigging. I had to use quite a lot superglue to fix it back. Luckily I managed to do it. I think the direction of the grains chosen wrong during the laser cutting of the part. It snaps with no force. Hopefully no more snapping during further rigging, I will be also extra careful with tension of the threads fitting to these pins. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
I`m glad you could fix the broken pin! Greetings, Walter
All looking good, your efforts are paying off very nicely.... Regards Alan
Hello All, After couple of days quietness here are some updates. Issue 107 started: - fore topgallant sail rigged and fitted Then due to the next step require to work around the mizzen mast I stopped here, as the replacement mizzen topgallant staysail still hasn't arrived. I was not sure if the steps in issue 107 will disturb/block the fitting of the last staysail. Issue 108 skipped for now for the same reason. While waiting I started issue 109 with the 18-foot cutter: - building frame assembled - planking completed - cutter removed from frame and sanded smooth - keel fitted. I found a fairly big gap at the bow between the planking and the curve of the keel, so I filled it up with wood filler I didn't complete the last few steps with the inner planks and the grating as I will paint the inside first yellow ochre. I put this aside now and paint together with the other three boats later on. The replacement sail arrived early this week.  Done the soaking in tea exactly as I done with the other sails... of course, Murphy's Law took effect... it ended up with a darker shade  . This sail must have a slightly different material, as I followed my previous soaking process precisely. Anyhow... I tried to wash it through with cold water, hoping that it will get lighter.... unfortunately it didn't... Tonight I'll test fit onto the ship to see how much the difference is noticeable. If it's easy to see then I might will to soak it for clean water for a while, hoping that it will get lighter. Have you got any other suggestion how to make it lighter? gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
