80 Pages «<1819202122>»
#381 Posted : 22 October 2018 09:20:28
arpurchase wrote:
BigGrin Looking good Phil and some cracking figures you have found to enhance your buildCool
Thank you Andy!BigGrin Cool Yes, I was quite surprised when I found the Kommandant figure in 1/48. Never heard of Andreas Miniature of Spain before either who supplied it.
#382 Posted : 24 October 2018 15:05:58
Hi Phil,
Awesome work, well done - great work on your radar.
#383 Posted : 24 October 2018 20:09:59
Garth wrote:
Hi Phil,
Hi Garth, thanks for looking in mate!Cool Glad you like the work so far!
kpnuts
#384 Posted : 24 October 2018 21:05:54
Amazing additions mate.
#385 Posted : 25 October 2018 09:43:24
Thanks very much Ken!Cool
#386 Posted : 25 October 2018 13:50:18
Great work as always. Some great finds on the details, it's going to look very impressive.
#387 Posted : 25 October 2018 15:34:06
Thank you very much Graeme!Cool. Another weekly update to follow later this evening.
#388 Posted : 25 October 2018 16:12:23
Hi Phil,
There's a lot of fine detail you've added there ThumpUp
You must have the patience of a saint, and the eyes of a hawk!
Excellent results thoough Drool
Gray
#389 Posted : 25 October 2018 19:29:04
CaptnBirdseye wrote:
Hi Phil,
Gray
Thank you very much Gray!Cool I'll admit, i do have plenty of patience, but not without plenty of planning beforehand so i fully understand how to achieve the end result. Eyes of a hawk?LOL In the past maybe, now i wear glasses for all my modelling work!Blink
#390 Posted : 25 October 2018 19:41:12
This weeks update continues with modifications to the conning tower of my 1/48 scale model of U-boat U230.
Last week saw me scratch building the wire antennae radar mast and this week I completed it by adding a few more details.
The attached photo shows the first of three terminals being fitted. Made from 2.5mm round plastic rod, cut and filed to length, with a 1.0mm hole drilled through the centre.
#391 Posted : 25 October 2018 19:42:42
The three terminals fitted, with the central terminal slightly off centre to the top and bottom as per U995.
#392 Posted : 25 October 2018 20:14:49
Earlier in the week I ordered some 1.0m diameter brass rod. In this photo, I've cut a small length and bent it to connect the central terminal to the wire antennae frame. In reality the signal would then be transmitted down the mast and onto the Radar Shack to be read by a radio operator.
#393 Posted : 25 October 2018 20:16:07
Brass rod bent and fitted.
#394 Posted : 25 October 2018 20:16:39
From another angle.
#395 Posted : 25 October 2018 20:18:43
Second terminal connected to the wire mesh antennae frame via 1.0mm diameter brass rod.
#396 Posted : 25 October 2018 20:19:32
Close up.
#397 Posted : 25 October 2018 20:20:36
The third and final terminal connected with the brass rod.
#398 Posted : 25 October 2018 20:24:15
The attached photo shows the first of two paddle shaped receptors. Made from 0.5mm thick plastic sheet and drilled out to accept a length of 0.5mm diameter brass rod. This will then attach to the antennae frame. Very tiny!Blink
#399 Posted : 25 October 2018 20:24:46
The second of the receptors.
#400 Posted : 25 October 2018 20:26:23
I then filed each one to round off the corners as per U995. The attached photo shows both receptors shaped and contoured.
Guest (10)
This page was generated in 0.497 seconds.
