Problem with wheel covers Options
deadlycowpat95
#1 Posted : 11 July 2011 21:48:27
Rank: Newbie
Hey, Right now im up to part 8 and im suffering a problem.
The wheel shaft will not fit into the upright correctly, the top of the shaft does not go all the way into the hole.
I have tried as many things as I possibly can think of but still wont go in.
Can anyone help?
#2 Posted : 11 July 2011 22:27:57
Is it possible to show a picture of the problem you are having? Hopefully then we can help you..
deadlycowpat95
#3 Posted : 11 July 2011 23:58:30
Rank: Newbie
Here you go:
This is as far as it will go.
#4 Posted : 12 July 2011 08:59:33
The hole should be hexagonal shape to stop the shaft from spinning so it looks like to me it might me a dud hub with the wrong shape hole and depth... Send a PM to Admin to see if you can have the parts re-sent.. I would suggest heating the shaft so that it "melts" its way into the correct possition or if you can drill out the hole to the right size and depth checking each time you do a bit then a dop of superglue to secure it in there..
Spencer
#5 Posted : 12 July 2011 09:12:30
If the hexagonal stub of the axle was not perfectly aligned and was forced into the upright, then its unlikely you'll get the axle located thereafter because it will have damaged the corresponding hexagonal alignment sleeve of the upright. Best way is to replace the upright or attempt a fix as Warthog has suggested.
#6 Posted : 12 July 2011 11:34:46
-I nearly had the same prob,I had a look at the hole with magnifying headset,and saw that the bolthead had been misaligned slightly,so used a very small file and a sharp blade to recut shaped hole.and all was well.
Skiddy
#7 Posted : 12 July 2011 12:48:05
I think it's near impossible to build this properly without a magnifier unless you have eyesight of an eagle Laugh
Austin
#8 Posted : 12 July 2011 21:19:45
There quite stiff aswell, you need to really force them in, even when they are lined up. Anyway, how old are you guys, you all need magnifiers? BigGrin
Skiddy
#9 Posted : 12 July 2011 23:40:47
96 and still brush my own teeth Wink
lholland
#10 Posted : 13 July 2011 10:01:09
I struggled getting those pieces in too so I used the back (flat part) of my scalpel and they went in perfectly without damage.
deadlycowpat95
#11 Posted : 22 July 2011 20:24:34
Rank: Newbie
Thanks for the help guys :)
I managed to force it in using a little bit of Vaseline. good to know I can finally get on with my build.
#12 Posted : 22 July 2011 20:49:44
yep and I brush mine in a bucket,with me false eye,and wooden leg.
#13 Posted : 22 July 2011 21:15:31
Blink
scotty2hotty
#14 Posted : 23 July 2011 09:14:49
Blink
LOL
This page was generated in 0.263 seconds.
