7 Pages «<34567>
Mr.Quist's build diary Options
cal
#81 Posted : 11 July 2011 21:36:54
looking fantastic is your build mr Quist ive jsut finished one side of the lower hull & really pleased how its turned outBigGrin BigGrin
Sietse
#82 Posted : 13 July 2011 10:28:22
Holly molly, Am I lucky!!! Rib 30 is in line with my others ribs.
Albatross, build in 1982 from plans.
Hms Bounty, build in 1987 from plans.
Duyfken,build in 1991 from plans
Oosterland, build in 1998 from plans
2010 Hms Victory kit from Deagostini
In the meantime.
2011 Building MFV 1963 fishing trawler from plan.
jonny7england
#83 Posted : 13 July 2011 10:36:13
Well done Timm!! Glad you got around your problem without major rebuilding..she's looking real good mate...keep us posted...ThumpUp
Mr.Quist
#84 Posted : 15 July 2011 13:41:44
Hello shipmates,
another day at the shipyard.
issue #41:
After unpacking I found THIS:
One part was not like it was supposed to be.
Took a bit of cutting, gluing and sanding to make it fit.
The bottoms of the gallery sides still have a little gap, couldn't get it closer.
Will this be an issue ???
issue #42:
The wales
I found it quite difficult to attach the wales, because the magazine did not tell precisely where to attach them.
So I started with the middle wale and just fixed it with nails (no glue yet) and start shaping it into position.
Then I attached the second line of planks below. These where glued and nails.
Afterwards I removed the first line and glued it back again.
The "swing" of the wale look okay for me.
The 1x5 mm planks are extremely brittle and start to frazzle very easy.
To be continiued......
Timm
My build diary here
HMS Victory
Foz
#85 Posted : 15 July 2011 15:15:59
Timm
Shes looking really fine, keep those pics coming.
I also have a small gap on the gallery in the same place as you but there are other parts to add there later that i am hopeing will cover the gap.
Foz
jonny7england
#86 Posted : 15 July 2011 15:53:16
Hi Timm the gap in my gallery is identical to yours mate...Looking real good though...Did you get sorted with Endeavour???
Mr.Quist
#87 Posted : 15 July 2011 17:01:30
Not yet mate. Looks like it has not being published in Germany so far. Also haven't found a german branch of eaglemoss yet. But I dropped them an email. See want happens.
That is a model I've always been looking for, especially in that big scale.
But first I have to get on with this one anyway ;-)
Timm
My build diary here
HMS Victory
#88 Posted : 15 July 2011 17:33:56
Why not simply buy the donor model the partwork version was spawned from which is far better quality and has a far better content
http://www.occre.com/ind...roduct&idproducto=94
Mr.Quist
#89 Posted : 15 July 2011 18:15:05
Thanks Mr.T,
will keep that in mind.
Looks pretty similar and the price is okay too.
But to be honest, even if it is more expensive, I really like the idea of a patchwork kit like our victory. I presume that they have the more detailed assembly guide (correct me if not) and I truly enjoy it joining a group of people doing the same thing, sharing there builds and helping each other. As this is my first ever wooden ship model, it is a big advantage for me.
.. as long as the quality is alright.
Timm
My build diary here
HMS Victory
Mr.Quist
#90 Posted : 17 November 2011 14:08:44
Hello shipmates,
it's four months ago I paused work on my Vic. Finally found time to continue the build.
issue #43:
Finishing the whales. Still not happy with the color of the stain.
issue #44:
This bottle of wine had the exact diameter for the decorative strip of the bow. Took me a lot of bottles to find out.BigGrin
To copy the "flow" of the first strip (left), I marked its position with folderback clamps before gluing the second strip (right).
issue #45:
My first attempt to plank like in the instructions of the magazine. But during the work I remembers Darrons post about the gap beeing too wide here. So I made them smaler. Orininally the gap had a width of seven planks, I reduced it to five. See if it works.
Timm
My build diary here
HMS Victory
Son of Bulwark
#91 Posted : 17 November 2011 18:02:01
Hi Timm! Cool
Look's GREAT! I'm happy you made the change to the upper deck opening’s at this point, now that is the easy way to do it! just think what it was like to find out after fitting the quarter deck.
A 25mm wide opening is just about right for the narrower grates but if you need to open it a little more after the grates are made then that's simple.
The wine bottle idea is the best idea yet! I take it you have to drink the bottle first before testing it with a plank to check the shape of it curve just in case the bottle tips over and makes a mess!
Great to see you building again Timm! ThumpUp
Darron
#92 Posted : 17 November 2011 19:15:52
Timm your build and attention to detail is outstandingBigGrin Cool
Gerrit
#93 Posted : 18 November 2011 05:47:51
Welcome back and congratulations with this build to date. It really is amazing how much attention is given to detail. Keep it up
jonny7england
#94 Posted : 18 November 2011 09:10:03
Hi Timm, great work, looking real nice mate, and good to see you back on the forum...ThumpUp
Mr.Quist
#95 Posted : 18 November 2011 16:18:27
issue #46:
a flexible steel ruler, jammed between a desktop lamp and the model, is great tool to softly press the tiny plank bits against the other planks while the glue is drying.
the stained deck.... even though the planks are free of pva and slightly sanded, the planks don't get stained well. Maybe I have to it a second or third time.
Timm
My build diary here
HMS Victory
S2ksean
#96 Posted : 18 November 2011 17:58:31
Doing well with this build mate
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#97 Posted : 19 November 2011 23:47:19
Love this build, just shows the value of taking your time to get it right BigGrin
Atholm
#98 Posted : 20 November 2011 09:01:09
She is coming on beautifully keep up with the excellent close up photos.
Happy building
Athol
Mr.Quist
#99 Posted : 13 December 2011 23:50:23
issue #45 reloaded:
I am rebuilding the second deck from scratch. Tom's build convinced me to do it his way.
Started with some leftover beechwood-sticks 8x8 mm as support and some 4 mm plywood. Planked with 0,5 mm walnut veneer. Still a bit messy, I haven't sanded and oiled it yet.
Now the height of the cannons seems to be correct.
A lot of work but worth the try.
During the work I had the idea of already adding the threads for the gunport lids (15 cm thread each gunport), as the holes won't be accessible later on. Hopefully this will save me a lot of tricky work. If not, the y can be easily remove.
For the lowest deck it's too late now, but I will continue this whit the gunports to come.
Good idea ? Bad idea ?
To be continued......
Timm
My build diary here
HMS Victory
#100 Posted : 14 December 2011 00:58:57
Great Build TimmBigGrin Cool
7 Pages «<34567>
This page was generated in 0.179 seconds.
