Stern re-inforcements (Parts 32) Options
Gan_Javi
#1 Posted : 11 July 2011 00:56:31
Hi Shipmates,
I have been struggling to get the correct stern frame (pt 31). After 2 re-issues I still did not get the correct part, so instead of just quitting the model, I decided to make one myself from my doubles. It did not look to bad, and I have the stern reinforcements on it. I just want to know something, do they form a slight curve up to the middle?
Francois
#2 Posted : 11 July 2011 09:32:45
Hi Francois, drop a photo on to show the part you are talking about, thanks.
#3 Posted : 11 July 2011 09:39:18
Have a look at Mr t`s official build 16 -20
Mr.Quist
#4 Posted : 11 July 2011 13:31:43
Hi Francois
Make sure your frame 30 is in the correct place and ALL the way down in the slot, so that all deck supports are in one line.
Otherwise you will end up like me.
http://forum.model-space...s&m=29313#post29313
Cheers, Timm
My build diary here
HMS Victory
Deepseacodmaster
#5 Posted : 11 July 2011 16:33:51
Mr.Quist wrote:
Hi Francois
Cheers, Timm
Hi Timm and Mr T
Looks as if I have made the same mistake,see photo (I cannot have pushed the frame home properly.) Cursing Cursing
I intend to cut out the shaded area to bring the frame to the correct hight.Glue the two halfs together, with a doubler inside the model body to strenghen the joint.
Any other ideas or sugestions would be welcome if anybody can come up with an easier solution.
Thanks for the post which came in time before I got too far into the build Blushing Blushing
First Build HMS Victory and HMS Endeavour
Also Krick steam boat "Victoria"
Cheers
Ivan (Ordinary Seaman)
http://www.old-glossop.com
StefanDV
#6 Posted : 11 July 2011 16:36:14
Francois,
I also made my own part 31 and also have a slight concave bend towards the stern of the ship (maybe 1 mm)
#7 Posted : 11 July 2011 16:55:12
Deepseacodmaster wrote:
Mr.Quist wrote:
Hi Francois
Cheers, Timm
Hi Timm and Mr T
Well at least you've spotted it and you now have the info to hand in how to sort it Cool
StefanDV
#8 Posted : 11 July 2011 16:58:05
Francois,
Tomick's also curves slightly, see photo nr 4 &5 in post#5 here http://forum.model-space.co.uk/default.aspx?g=posts&t=1573
Gan_Javi
#9 Posted : 11 July 2011 18:04:34
StefanDV wrote:
Francois,
Ok, so that slight concave curve is normal?
Son of Bulwark
#10 Posted : 11 July 2011 19:00:53
Hi shipmates! Cool
In Deepseacodmaster post about this problem.
I think you have come up with the best method for you thanks to you spotting it before are have planked over that area. There is only one way that can solve the problem easier and that is to check the ribs has gone down to the correct point in the first place, I'm not being funny! REALLY I'M NOT!. The glue can stop the ribs fitting all the way down, it's not your fault it just happens, it happened to me on the same rib only I check my lines and they didn't match so quickly pull the rib out washed the glue off, then sanded the slot wider.
A tip to anyone about to fit the ribs to the keel mark the ribs and keel across the end of the slots on both parts so you know were the slot ends as you fit the rib. If the line on the rib almost touches the line on the keel then you’re at right point, it's that simple and will save you a lot of trouble later.
Deepseacodmaster
#11 Posted : 12 July 2011 22:19:33
Repair/mod/fix call it what you will,
Seems to be strong enough and I only have to pack out the edje of the frame as I plank it.
BigGrin BigGrin
Cheers
#12 Posted : 12 July 2011 22:35:54
well done mateLOL BigGrin
#13 Posted : 12 July 2011 22:40:44
Looks drastic, but once she's planked up the fix will be hidden, well done!
Foz
#14 Posted : 13 July 2011 09:35:40
Well done on getting your problem sorted out, and beore you finish the planking.
I had problem there and ended up doing same things as you but i had done all the planking and did not find out till then that i had a teist in mine when Mr T spotted it on a pic i posted.
So your build can only get better from now keep the pics coming.
Foz
Deepseacodmaster
#15 Posted : 13 July 2011 12:49:22
Thanks everybody for the kind remarks about my problem solving.
I think I might start an "Ivans build mistakes and problem solving" topic.
It might stop other new builders from making the same mistakes
LOL
Cheers
This page was generated in 0.142 seconds.
