80 Pages «<1213141516>»
#261 Posted : 04 October 2018 08:36:38
Third set.
#262 Posted : 04 October 2018 08:37:48
Fourth set.
#263 Posted : 04 October 2018 08:39:49
Fifth set.
#264 Posted : 04 October 2018 08:41:21
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
#265 Posted : 04 October 2018 10:51:06
The Crew will look great on your model!
#266 Posted : 04 October 2018 11:38:09
Thank you Walter!BigGrin Can't wait to start painting them and adding all the small details.BigGrin
#267 Posted : 04 October 2018 14:41:51
Great work with the conning tower, it's looking really good. Great find with the figures, they will certainly look the part on and around the boat.
#268 Posted : 04 October 2018 15:34:16
Great work, the figures are going to be a great addition.Love
#269 Posted : 04 October 2018 15:49:10
Great work on the upper deck and those figures look perfect for your crewCool
#270 Posted : 04 October 2018 18:05:48
Thank you Graeme!Cool I'm very pleased to have sourced the figures and they all have their own character too.
#271 Posted : 04 October 2018 18:06:50
Thanks very much Mark!Cool Can't wait to start painting them up!
#272 Posted : 04 October 2018 18:10:03
Thank you Al!Cool They all have their own character so will fit right in on the U-boat.
#273 Posted : 05 October 2018 13:16:49
Really top work as always PhilLove the figures look greatBigGrin i did notice on Shapeways there are u-boat crew figures on thereDrool regards PhilCool
#274 Posted : 05 October 2018 14:01:27
Thanks very much Phil!Cool Yep, I've spotted those figures before on Shapeways and will probably buy a pack 'to make up the numbers' so to speak. To be honest though, they all look the same and very generic in their facial features and clothing. That's why I prefer the Hecker & Goros pewter figures as they all have their own characters, whether it's facial expressions or different types of clothing. U-boat submariners didn't have a 'regulation' uniform like the army when at sea. In my time while serving on O- class diesel submarines, we could wear anything while on patrol. Most of the time it was overalls and t-shirts, but occasionally, you would get a few wearing Bermuda shirts. This was known as 'pirate rig'. BigGrin Coupled with the fact we didn't have to shave, there were many faces with walrus moustaches, long beards or Elvis sideburns.LOL
#275 Posted : 06 October 2018 00:06:05
BigGrin I agree the figures you have bought are far more realistic to the others its just getting the paint jog right on them thats the challenge nowCool
#276 Posted : 06 October 2018 08:39:27
Love the figures, these will certainly bring the build to life.... Look forward to seeing them painted up and in situ.....Cool Cool
#277 Posted : 08 October 2018 11:32:13
Thanks Andy!Cool Got to do a bit of research on paints, colours and tones first before I start.
#278 Posted : 08 October 2018 11:33:29
Thank you Alan!Cool My aim is to create a mini diorama within in each compartment, so that every section tells a story.
#279 Posted : 11 October 2018 07:55:51
This weeks update continues with adding modifications to the conning tower of my 1/48 scale model of U-boat U230.
All of Monday evening was spent researching the different variations of conning tower sported by Type VIIC U-boats during WWII. Many and varied is the answer. The conning tower of U230 evolved over time, not only gaining a lower deck for an additional 3.7cm flak gun which I've mentioned before, but also the shape due to improved antennae, protection for the crew via armoured boxes and the relocation of the air intakes for the diesel engines.
I decided to modify these air intakes first. Type VIIC's have their intakes routed from the engines via trunking before running up the inside of the conning tower, on both sides, to their respective inlets. Early Type VIIC's such as U96 had their inlets located on the outside rear edge of the conning tower as seen in the photo attached, taken from the supplied part-works instructions, part number 242. This is the 'grille' type intake, whereas U230 sported wire mesh, more of which later.
#280 Posted : 11 October 2018 08:02:19
U230's inlets however were located on top of the trunking and fitted with wire mesh as opposed to the 'grille-type' mentioned before. The reason these inlets were moved was due to the addition of improved antennae which required a box section being added to the port side and an armoured box on the starboard side. I will cover the making of these in future updates.
The attached photo shows the top of the trunking being drilled out. At this stage, the fairing that incorporates the top of the trunking is not glued in place.
Guest (5)
This page was generated in 0.518 seconds.
