80 Pages «<1112131415>»
#241 Posted : 04 October 2018 08:09:53
When the glue was dry, i carefully smoothed their edges with a homemade sanding stick.
#242 Posted : 04 October 2018 08:10:40
Continuing around all edges with the sanding stick.
#243 Posted : 04 October 2018 08:12:04
Once i was happy all the edges were smoothed i added filler to any gaps.
#244 Posted : 04 October 2018 08:12:55
All filler sanded smooth on the starboard side.
#245 Posted : 04 October 2018 08:13:36
All filler smoothed out on the port side.
#246 Posted : 04 October 2018 08:15:06
The next job was to add an edging strip similar to the one i used for the lower deck; 1.0mm x 1.5mm strip.
The attached photo shows the first section being bent to suit.
#247 Posted : 04 October 2018 08:15:58
Taped in place and glue applied.
#248 Posted : 04 October 2018 08:17:19
Tape removed and glue applied to sections that were covered over.
#249 Posted : 04 October 2018 08:19:28
Continuing around the perimeter of the upper deck using the same technique. I purposefully left all strips slightly over length as it was easier to trim once the glue was dry.
#250 Posted : 04 October 2018 08:20:07
The same section on the opposing side.
#251 Posted : 04 October 2018 08:20:56
Continuing around the perimeter.
#252 Posted : 04 October 2018 08:21:38
The last of the longer sections fitted.
#253 Posted : 04 October 2018 08:22:50
The last two small sections added, connecting the edging strip to the conning tower body.
#254 Posted : 04 October 2018 08:23:48
A view from the port side showing the last of the edging strip fitted.
#255 Posted : 04 October 2018 08:24:39
Looking at the starboard side.
#256 Posted : 04 October 2018 08:25:22
Trimming the edging strip.
#257 Posted : 04 October 2018 08:25:59
Upper deck completed.
#258 Posted : 04 October 2018 08:26:37
From another angle.
#259 Posted : 04 October 2018 08:33:55
That concludes this update. I've recently discovered that Hecker & Goros, whom i originally bought two sets of pewter 1/48 scale U-boat figures has produced a further 5 sets. Ace! So i ordered these last week and they have arrived. It brings my total U-boat crew to 18. They are all full of character and i can't wait to start painting these up. Granted i will require a few more figures to really convey the feeling of being in a cramped work space, but it's a start.
The first set to arrive.
#260 Posted : 04 October 2018 08:34:51
Second set.
This page was generated in 0.607 seconds.
