Hi, I would really appreciate help!
I'm currently trying to fit the radiator/panel/bulkhead assembly to the chassis (issue 77).
Everything seems fine apart from the shock piston (part 76-1) seems to be too far wide of the shock body (part 76-4) and I have ended up breaking the piston and the upper arm (part 42-1) (requested replacements).
I can locate the position of the screw points on the chassis to the assembly fine, but the piston does not locate in the shock body.
I really don't know what I've done or what to do!
Please help!
Thanks, Matt
Hi Matt Could you provide some pictures of the area where your problem is please. Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
