Help needed please - build - issue 77 Options
Matt_73
#1 Posted : 03 October 2018 17:43:04
Rank: Newbie
Hi, I would really appreciate help!
I'm currently trying to fit the radiator/panel/bulkhead assembly to the chassis (issue 77).
Everything seems fine apart from the shock piston (part 76-1) seems to be too far wide of the shock body (part 76-4) and I have ended up breaking the piston and the upper arm (part 42-1) (requested replacements).
I can locate the position of the screw points on the chassis to the assembly fine, but the piston does not locate in the shock body.
I really don't know what I've done or what to do!
Please help!
Thanks, Matt
#2 Posted : 03 October 2018 23:39:16
Hi Matt
Could you provide some pictures of the area where your problem is please.
This page was generated in 0.123 seconds.
