This practical set of basic ship modelling tools from Artesania Latina comes with a number of professional tools to assist with building your ship.
This tool kit includes:
Nº1 modelling knife: The modelling knife has many uses throughout model making, has an aluminium handle and interchangeable blade.
Pin-nailer: Used for inserting pin-nails into wood. Specific for naval modelling.
Archimedes mini-drill: Complete with an additional collet and 1mmm drill bit. Perfect for use with wood and soft plastics such as polystyrene.
Side cutter pliers: For cutting of wire, plastic, soft metal and wood. Oblique cutting pliers, with protected anti-slip handles.
Snip Scissors: Japanese style snips, ideal for working with the rigging threads of our ship models. Precise cut, easy handling and very sharp tips.
Sanding block: Used to support sandpaper for a more comfortable control, with rounded and sharp shapes, it's ideal for sanding wood.
https://www.model-space....-modelling-toolbox.html Tomick attached the following image(s):
This is a great little starting set for the ship modeller. Getting essential tools in one set for a great price. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Great little starter set for budding ship builders Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
