 Rank: Beginner Level 2   Groups: Registered
Joined: 18/06/2011 Posts: 11 Points: 42 Location: Belfast
Excellent progress! Keep up the good work, well done!
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
Well done Jim, great job with planking. I bet you've had enough of shaping, tapering, bending, snapping, and trying it all over again Keep up great work
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Jim. A nice build you have there, and the milestone has been reached, well it was for me when i finally finished planking the hull, only onwards and upward from now. Keep up the good work and keep those pics coming.
Foz
 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 02/05/2010 Posts: 67 Points: 201 Location: Staffordshire
Thanks for all the possitive feedback guys. It was a long old job but worth it. Makes one feel very proud, just sitting back looking at the ship. So imagine what it will be like when it is finished!!!! The only tool I used to plank the whole hull was the plank benders enclosed in the toolbox. They worked a treat. The only thing in there which worked. I didnt have to resort to curling tongues, soldering irons, etc. Just pins, and a dab of really strong superglue at the end of each plank to keep it in place while the wood glue dried. So I am very pleased. Now onto the sanding. Looking forward to doing something different for a while. Thanks again everyone. Jim
Well Done Jim MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 22/03/2010 Posts: 369 Points: 1,150 Location: Broadstairs
Nice build coming along there Jimbo, keep the pic's coming. TIS
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Hi Jim, looking very good. I'm also using the enclosed plank-bender - glad to hear that it will do the job. How did you do the compound curves?
Hi Stefan, They werent too hard. I just made sure I really gave the planks a good work over with the plank benders. Also, do not underestimate the power of superglue. I always put some at the end of the plank to hold them im position while the wood glue dries. Finally, I also made sure I didnt soak the wood for too long, cos it made the planks kind of brittle.
Good luck with it all
Jim
So you soak the planks for a couple of minutes in hot water before "cutting" them with the bender?
Hi Stefan, Sent you a PM
Jim
