80 Pages «<89101112>»
#181 Posted : 21 September 2018 08:15:45
arpurchase wrote:
BigGrin That gun looks the bizz and the towers looking goodCool
Thanks Andy!Cool The conning tower is slowly getting there. I'm very happy to have found the guns I was after in 1/48 scale. I may replace some of the smaller details with photo-etch, but I'll wait until I actually start work on them before I decide.
#182 Posted : 21 September 2018 08:36:44
Fabulous work and very impressed with those guns.. build is going to be amazing when finished....Drool Drool
#183 Posted : 21 September 2018 09:34:03
Thank you Alan!Cool I can't say enough of how pleased I am in sourcing the correct guns in the correct scale. It has saved me a lot of time.
#184 Posted : 21 September 2018 11:29:13
Well done Phil i have ordered parts for the delorean from shapewaysCool great service well packagedBigGrin those guns look the businessDrool can`t wait for moreDrool regards PhilCool
#185 Posted : 21 September 2018 12:36:08
Hi Phil, yes, Shapeways provide a really quick service; a week from ordering to delivery.
The flak guns are great aren't they. Stay tuned for more updates.Cool
Phil W
#186 Posted : 21 September 2018 20:54:16
Those guns look the business PhilCool a worthy addition to your cracking build.
#187 Posted : 21 September 2018 23:14:53
I really like them guns. I'm gonna have a nosey at shapeways. Look forward to seeing them with paint on.
#188 Posted : 24 September 2018 09:13:41
Thanks Al!Cool So pleased to find these guns in 1/48 scale!
#189 Posted : 24 September 2018 09:15:52
Thanks Chris!Cool Can't wait until I get to that stage and paint them up! Yes, check out Shapeways, you never know what you may find!
#190 Posted : 24 September 2018 13:51:27
I´m glad you found those guns - they look awesome - as is your whole build!
I also can only recommend shapeways - i used some of their parts for my victory (stairs, belfry, roundhouse decorations)!
#191 Posted : 24 September 2018 14:22:14
Thank you very much Walter!Cool I think I will keep a close eye on Shapeways regarding future releases.
#192 Posted : 24 September 2018 14:39:24
Hi Phil.
Great work on your hull mods.
Those deck guns look really good. look forward to seeing what you do with them.
Ian Cool BigGrin Drool
#193 Posted : 25 September 2018 09:25:43
ian smith wrote:
Hi Phil.
Thank you Ian!Cool I'm so pleased to have found the correct guns. I will probably strengthen them as they're a little fragile and maybe add some etch here and there.
#194 Posted : 27 September 2018 07:21:17
This weeks update continues with scratch building modifications to the conning tower of my 1/48 scale model of U-boat U230.
To attain the correct height of the upper deck I fitted square profile plastic strip. Last week saw 6.0mm square strip added and this week I fitted 4.0mm square strip to bring the total height to 10.0mm.
The attached photo shows the additional 4.0mm square section strip fitted.
#195 Posted : 27 September 2018 07:21:57
From another angle.
#196 Posted : 27 September 2018 07:25:01
The next step was to measure the upper deck profile of my 1/72 scale donor model and transpose those measurements, multiplying by a factor of 1.5 and draw out on 0.5mm thick plastic sheet.
The attached photo shows the upper deck profile marked out and ready for cutting.
#197 Posted : 27 September 2018 07:27:28
Upper deck profile cut out. The two small holes, drilled out to 1.0mm diameter, are the locations for the two, twin barrelled 2.0cm flak guns mentioned in last weeks post.
#198 Posted : 27 September 2018 07:28:11
Upper deck being checked for fit. Not glued at this stage.
#199 Posted : 27 September 2018 07:28:47
From another angle.
#200 Posted : 27 September 2018 07:31:54
Once I was happy that the upper deck fitted well I then put it to one side and concentrated on the deck of the conning tower itself.
The attached photo shows the part-works supplied part that makes up the deck of the main conning tower. The round section has to be removed so that the remainder will fit into the tower.
This page was generated in 0.330 seconds.
