cutting and cleaning out gunports holes Options
ronald305
#1 Posted : 19 September 2018 14:55:20
hello there fellow ship modelers
before I start cutting out the gun ports is it ok to be a tad under size hole wise like for example instead of 12mm on all corners it is 1.97 or 1.99 etc. because I tried several time to make a jig that is 12mm X12mm I seem to miss the 12mm measurement also can I just clean out the square hole with a sanding stick if I do not have a square file. by the way Alan can you tell me where you got your square file from thank you
Ronald
#2 Posted : 19 September 2018 16:22:03
Perma-grit 6.5mm square file fine
https://www.permagrit.com/square-file-6mm-fine/
z8000783
#3 Posted : 19 September 2018 16:28:09
Groups: Unapproved
I bought some ladies emery boards for nails from John Lewis or similar. They are exactly 12 mm at the widest point and ideal for sanding to the correct size.
#4 Posted : 19 September 2018 17:42:08
Hi Ron,
The instructions call for the ports to be 12x12mm therefore you should make your ports as close to this as you can. It can be easily achieved by using emery boards, the same kind as ladies would use for their nails. Just check your size frequently until you have the size needed.
My files are part of a set.
https://www.permagrit.co...and-tools-in-roll-fine/
ronald305
#5 Posted : 19 September 2018 17:54:30
thanks everyone
I need to decide either buy the emery boards or the perm grit square file or file set I doubt I will be able to find any john Lewis emery boards or the permi grit files in the US but I look for something similar
Ronald
#6 Posted : 20 September 2018 07:09:01
BigGrin Link to US Perma-Grit distributor below:-
http://www.bvmjets.com/pages/catalog/permagrit.htm
ronald305
#7 Posted : 28 September 2018 16:14:56
Hi Alan
you didn't mentioned it in the video but did you use a ruler or calipers to
make sure the gun port holes were 12mm X 12mm I hope they do not need to be
perfect close maybe I will try to get them at 12mm thank you
Ronald
#8 Posted : 28 September 2018 17:46:26
ronald305 wrote:
Hi Alan
Ronald
Hi Ronald, normally I check the ports by making up a jig. Made one up from a wooden strip that was 12x12mm…..
ronald305
#9 Posted : 30 September 2018 18:41:23
I've tried to make one out of pieces of tin first then out plywood left over from the bow fillers, I will try to make one like you have in the picture
Ronald
ronald305
#10 Posted : 30 September 2018 19:35:29
can't promise it will come right I have been using digital calipers and a 6" ruler
Ronald
This page was generated in 0.174 seconds.
