Tile Pack Options
ENJAY49
#1 Posted : 13 October 2017 00:31:59
Rank: Amateur Level 2
About to order a subscription, and I see Tomick, last December, advised to order the copper tiles while supply lasts. Is it still the case that the supply my run out?
Thanks for any reply.
Bruce
#2 Posted : 13 October 2017 01:01:02
The tiles are still on the site for purchase.
https://www.model-space....ck-for-hms-victory.html
arl
ENJAY49
#3 Posted : 13 October 2017 01:07:35
Yes, I see that, but wonder if I should buy now, or risk they'll be unavailable later in the build. Thanks for the reply.
Bruce
#4 Posted : 13 October 2017 06:56:37
There is no guarantee they will be re-stocked
z8000783
#5 Posted : 13 October 2017 09:06:23
Groups: Unapproved
If you know you are going to tile the ship, best order them now, Bruce.
ENJAY49
#6 Posted : 13 October 2017 12:02:38
Right, I'll play it safe and do just that, thanks!
Bruce
#7 Posted : 13 October 2017 16:46:30
ENJAY49
#8 Posted : 13 October 2017 20:37:52
Ordered today. I've previously read thru the instructions, (as well as beginning the official build diary on youtube), they're very clear. Thanks, Tomick, for the reply!
Bruce
ronald305
#9 Posted : 17 September 2018 17:19:40
Hello there
about the tile pack that model space sells, may I ask if they run out why wouldn't they restock the tiles and if that the case would it be cheaper to buy copper tape roll and what size works for the 1/84 scale Victory kit, when I'm ready to tile the ship and do I need to get a dimple roller for rivets marks thank you
Ronald
#10 Posted : 17 September 2018 21:15:16
ronald305 wrote:
Hello there
Ronald
To avoid the problem of the tiles going out of stock I would get them now, at least then you would have them in your possession.
There is a PDF instructions download which will guide you through the process of fitting the tiles. Here's a link:
https://forum.model-spac...aspx?g=posts&t=2981
If you go the copper tape route, which I wouldn't recommend, you would be on your own regarding fitting/application. The hull surface will need to have a gloss finish for good adhesion of the self adhesive tape, whereas tiles can be glued with contact adhesive. You will also need a pounce wheel/nail making tool for both the tiles and the tape.
ronald305
#11 Posted : 17 September 2018 22:11:48
yes you are right so I went and brought the tiles anyway along with a binder
Ronald
