centering the rear gun ports Options
ronald305
#1 Posted : 16 September 2018 13:50:27
Hello again new questions
would anyone know if the rear gun ports are suppose to be dead center or it critical if are there measurements to get it dead center because the instructions
do not mention anything on how to get it center only know about making the holes 12mm thank you
Ronald
#2 Posted : 16 September 2018 18:29:14
Hi Ronald,
As you don't provide any pics then I have to assume you are referring to the two gunports at the stern, under the gallery. Therefore, Stage 25, Section on 'Cutting the stern gunports', step 2 clearly says 'Draw two lines at right angles to the first two, positioning them 24 mm from the edge of the gallery support at the point where you drew the first lines. (See attached pic). If these are not the ports you are referring to then you'll need to give a little more clarity....
If you are referring to the last gunport on each side of the ship then Stage 23, step 6 says 'The gun port closest to the stern comes midway between frames 29 and 30. Make sure that you keep its sides parallel to the frames'. (See 2nd attached pic)
You should follow the measurements given in the instructions otherwise your stern gun ports will not look right.Cool Cool
Hope this helps...
ronald305
#3 Posted : 16 September 2018 18:43:27
sorry my mistake I didn't think I needed photos for the question I asked I was referring to the last gun port between bulkhead 28 to 30 according to instructions is should sit right above bulk head 29, also forgive to messy lines
and being side ways
ronald305 attached the following image(s):
ronald305
#4 Posted : 16 September 2018 18:49:58
yes I am referring to photo #6 but there is no measurements for marking the gun ports center
Ronald
This page was generated in 0.468 seconds.
