Main stay attachments - Issue 96 Options
gingerale75
#1 Posted : 12 September 2018 20:25:51
Hi All,
I’m on issue 96, fitting the two heart blocks.
There should be two threads go underneath the bowsprit.
One through the rear gammoning holes, I have no problem with this one.
However the second one, which supposed to be go through the hole between the two gammoning openings, impossible to make. Those holes are fully blocked by the bow frame between the two gammonings.
See photos attached.
There is nothing mentioned in the official build that it can be a problem, also no alternatives offered.
So where should I lead that thread through the grating?
Or shall I drill a hole through the frame?
Thanks in advance
PS sorry how the photos attached, posted from my phone.
Happy building!
Laszlo
gingerale75
#2 Posted : 12 September 2018 20:49:37
Ok. I made it simple, two holes drilled vertically through the beakhead frame. Cool
Happy building!
Laszlo
#3 Posted : 12 September 2018 22:51:37
Hi Laszlo, good to know you've managed to resolve your problem. I can't recall receiving any reports of anyone having a problem with this part of the build....
This page was generated in 0.139 seconds.
