Jaguar E-Type Official Build Diary - issues 81 - 85 Options
#1 Posted : 11 September 2018 20:23:33
Issue 81
Contents: Tyre, Washer,Screw
Take the tyre supplied with this issue, together with the finished wheel. Immerse the tyre completely in boiling water for a couple of minutes to soften the rubber. Carefully remove the tyre and dry it thoroughly. Before the rubber cools, slip the flange projecting from the rim between the sidewalls of the tyre. Quickly work round the tyre, stretching the sidewalls over the flange. This will take some force. Check that the tyre is evenly seated all the way round the rims on both sides.
Retrieving the rear floor assembly that you completed in Stage 57,fit the wheel over the left rear hub. Place the washer over the hole in the centre of the hub and screw the wheel into place.The screw that you just fitted will be covered by the knock-off wheel nut later on in the build.
This issue is now complete. Store the assembly and any unused parts in an issue labelled bag.
#2 Posted : 04 October 2018 18:23:50
Issue 82
Contents:Hinge assembly,Rear door,Screws x 4
Line up the components as shown.Fit the hinges over the lugs on the inside of the door.Holding the assembly together fit and tighten a screw into each of the four holes.
#3 Posted : 05 October 2018 14:37:48
Issue 83
Contents:Rear window glass, Chrome-plated retaining strip
Place the chrome strip over the glass so that the locating lugs go into the matching notches.Fit this assembly into the rear door so that the locating lugs go into the matching notches in it and press the chrome strip firmly into place.
#4 Posted : 07 October 2018 19:16:10
Issue 84
Contents:Rear door lining,Door stay,Stay hinge,Stay clip,Screws
Fit the stay hinge from the back of the door lining as shown, and press it onto the two locating pins.The two arms of the hinge should protrude on the other side.Fit the stay clip from the back of the door lining and press it onto the locating pin. Gently ease the two hinge pins on the stay into the holes in the arms of the hinge and press the arm of the stay into the clip.Align the lining with the door assembly and press it into position securing it with six screws around the window surround and two more at the base of the lining to the door.
#5 Posted : 05 November 2018 19:21:27
Issue 85
Contents: Bodyshell
There is no assembly to be done at this stage.
Carefully store the body for later assembly.
This page was generated in 0.212 seconds.
